reluctor wheel question
Old Dec 2, 2010 | 08:43 PM
GREG O.'s Avatar
GREG O.
Default reluctor wheel question
which LS motors share the 24 reluctor wheel vs the 58x.??thanks
Old Dec 2, 2010 | 08:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
All 97 -2005 LS motors share the 24x reluctor wheel.
2006 up use the 58x.
Old Dec 2, 2010 | 09:45 PM
Oldvetter's Avatar
Oldvetter
You used to have to change the reluctor wheel when you were putting a "different" engine in, now you can buy an "electric black box" which will make them compatible.
Old Dec 3, 2010 | 04:53 AM
GREG O.'s Avatar
GREG O.
Thanks, I have a 99 C5 LS1 and was thinking about replacing it with an LS3...so it looks like i will need the box I've been doing searches on the subject and saw Lingenfelter sells them.. If i purchased one, i wonder what a tunner would charge extra for install and labor for one of these thanks guys for the info so far.....
Old Dec 3, 2010 | 08:14 AM
LoneStarFRC's Avatar
LoneStarFRC
If you're installing a pre-assembled engine, seems like the converter box is the way to go. It's just easiest overall.
On the other hand, if you're building an engine, just choose a crankshaft with the 24 wheel. Most all the crank companies give you the choice. This is what I did.
To reluctor wheel question
