best place for an alignment
Old Apr 6, 2002 | 03:06 PM
quietgirl's Avatar
quietgirl
Default best place for an alignment
Who will do the best job on an alignment on our C5?
We're planning on having it done at 10,000 miles.
Old Apr 6, 2002 | 05:40 PM
Oldvetter's Avatar
Oldvetter
Default Re: best place for an alignment (quietgirl)
A mechanic once told me never get your wheels aligned unless your tires wear unevenly. The reason being that they are tightened at the factory and once they are loosened, they never get them as tight, so when you hit pot holes, etc. they will go out.
Used this advice on 3 cars and got excellant mileage from tires. One car went 165,000 miles without an alignment, always wore out tires evenly. It works for me !
Old Apr 6, 2002 | 06:30 PM
HOCKEY's Avatar
HOCKEY
Default Re: best place for an alignment (Oldvetter)
Same here as I have a 98 Jeep Grand Cherokee with 130,000 miles and got 101,000 on original tires and still never had an alignment and 20,000 on my C5 and no wear yet.
Old Apr 7, 2002 | 12:06 AM
CliffB-99's Avatar
CliffB-99
I would get the alignment. I've seen several C5s (mine included) with uneven tire wire on the inside edges of the front tires. I got mine aligned at the dealer when I bought new tires. I've heard others have good luck with the lifetime alignment deal from Firestone shops.
Old Apr 9, 2002 | 01:26 AM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: best place for an alignment (CliffB-99)
If your Dealer can't do it i'm sure they know of a good reputable shop they can refer you to .
Gd Lk
Jeff
[Modified by BLUTHUNDER, 5:27 AM 4/9/2002]
Old Apr 9, 2002 | 01:34 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
whatever you do, do not use a franchise type shop "brake check"
Old Apr 9, 2002 | 10:24 AM
bob98's Avatar
bob98
Default Re: best place for an alignment (knowledgefreak)
I went to the dealer and was satisfied after Goodyear screwed the alignment up bad, more money but definitely worth it IMO
To best place for an alignment
