Clutch
Old Dec 7, 2010 | 01:58 PM
jedblanks's Avatar
jedblanks
Default Clutch
I found lots of DIYs on the process of installing a clutch, but what I'm looking for are a list of parts I should have on hand when replacing the clutch and a recommendation of Brand/level of clutch.
I assume I have somewhere around 400 RWHP, with the Stock LS1 bottom end, 243 heads, vararam and 228/232 .588/.575 cam and tune.
Right now it's between:
LS7 clutch and Flywheel
Textrallia Z-Grip
RPS Twin
And then what else do I need / want?
new Slave?
new flywheel bolts? PP bolts?
Header gaskets?
remote bleeder?
pilot bearing?
Throwout bearing?
New Stiffer Tunnel plate?
I have new spark plugs and O2 sensors I will be installing in the process.
I guess I could replace the rear and trans fluids, but they are only ~1-2 years old Royal Purple
My current clutch is at least 10+ years old and probably close to 14. It holds ok, but I don't beat on it and if I do the pedal sticks to the floor.
Old Dec 7, 2010 | 02:09 PM
lucky131969's Avatar
lucky131969
Textrallia Z-Grip
RPS Twin
new Slave?
Header gaskets?
remote bleeder?
pilot bearing?
Throwout bearing?
new Slave? Yes
new flywheel bolts? PP bolts? Stock are fine
Header gaskets? As required
remote bleeder? Yes
pilot bearing? Yes
Throwout bearing? Comes with slave assembly
New Stiffer Tunnel plate? Not necessary
Old Dec 7, 2010 | 02:16 PM
zeevette's Avatar
zeevette
Of the three clutches you list, the RPS would be my choice, but there's lots of other options you don't list. The LS7 is the cheapest, and would probably work for your level, but it's very heavy, which is not a good thing, and it's not that strong, if you have future mods....very likely. The new factory slave comes with a TO bearing. If you get a Tick master, it comes with a remote bleeder. Get a new pilot bearing, but research using factory, or teflon might be better. Most clutch kits come with all the new bolts you need. Tunnel plate isn't needed unless you road race, IMO. Just remembered, one of our vendors had a good deal on a Fidanza dual disc, but I don't remember which one. You'll have to decide if you want an aluminum or steel flywheel, too.
Old Dec 7, 2010 | 02:25 PM
jedblanks's Avatar
jedblanks
From what I've gathered, aluminum is lighter, but steel is better for street use due to its heat sinking ability and manners.
Old Dec 7, 2010 | 02:45 PM
skyavonee's Avatar
skyavonee
Two good threads on flywheels:
http://forums.corvetteforum.com/c5-t...flywheels.html
http://forums.corvetteforum.com/c5-z...-flywheel.html
Old Dec 8, 2010 | 12:17 AM
jedblanks's Avatar
jedblanks
Well after reading that I come away with two things:
Aluminum Flywheel might be the way to go
and
I have to get the new flywheel balanced to the old one or it will vibrate. But what if the old one vibrates?
Old Dec 8, 2010 | 12:56 AM
LoneStarFRC's Avatar
LoneStarFRC
McLeod RST and flywheel
Tick master cylinder
Old Dec 8, 2010 | 01:53 PM
skyavonee's Avatar
skyavonee
and
The advice to eliminate vibrations is to have the new clutch/flywheel assembly balanced as a single unit before installation. However, if both the clutch and the flywheel are properly balanced from the factory separately (as they should be) then this step is unnecessary. So really it's just a check to make sure the factories did their jobs accurately. At least that's my understanding of it.
Old Dec 8, 2010 | 02:05 PM
LoneStarFRC
Correct. Cheap insurance considering the labor costs of pulling the drivetrain on a C5. I found the extra $100 (in my case) to be well worth it when getting my McLeod installed.
jedblanks's Avatar
jedblanks
Excellent, that's the insight I was looking for.
Do I have a machine shop check the balance / re-balance? Or how is it done?
Old Dec 8, 2010 | 02:14 PM
jedblanks's Avatar
jedblanks
Ok so now I am thinking:
a) New GM LS6 slave and TO bearing, with TICK remote bleeder new GM Pilot Bearing $200ish
b) One of the following (ascending order of price):
GM LS7 Clutch + LS7 Flywheel $450ish
GM LS7 Clutch + RAM Aluminum Billet Flywheel $600ish
McLoed RST Street Twin + My Flywheel (resurfaced) $650-$700
c) Optional:
Tick Adjustable Master (esp if I go with RST clutch). I have to option add it later right? $280
I really don't WANT to spend more than $1000 if i don't have to. I also don't ever want to have to change the clutch again. I'm not unusually hard on a clutch.
Feel free to add options if you think of something I missed, otherwise give me your thoughts on the best way to go.
Old Dec 8, 2010 | 02:16 PM
LoneStarFRC
Btw, Jed. When everything's opened up, go ahead and evaluate the condition of your driveshaft couplers.
On your clutch balance question, any machine shop that performs balancing work can usually accomplish this. Bolt together the clutch and flywheel as an assembly (with properly torqued fasteners) and check-balance together. Upon completion, they should be marked with a reference mark so you can bolt the assembly back in the car and have the correct orientation.
HTH
Old Dec 8, 2010 | 02:26 PM
LoneStarFRC
c) Optional:
If you are re-using your flywheel, then yes, get it Blanchard ground (surfaced) and then the clutch assembly would be bolted to it for final assembly-balancing.
If you go with the McLeod, you will love the "streetability" of it. Excellent street-driving manners and definitely not an "on-off switch" or "chatter puppy" like some high performance clutches are, plus it will hold even more torque than an LS7 clutch. The pedal pressure is almost identical to stock as well.
If you do decide to delay the Tick M/C, yes you can add it later if you so desire. No drivetrain removal necessary. I added it to my car at the same time as my clutch just as extra insurance against the dreaded "high rpm stuck clutch pedal" syndrome that I was experiencing before. Not anymore.
Old Dec 8, 2010 | 02:36 PM
skyavonee's Avatar
skyavonee
a) Although I think clutches typically come with a TO bearing, and sometimes even a pilot, so just make sure you don't end up purchasing duplicates.
b) stock LS7 clutch/flywheel is probably too heavy a combo for your car. I'd go with your 2nd or 3rd option.
Old Dec 8, 2010 | 02:41 PM
jedblanks's Avatar
jedblanks
Is there anything particularly wrong or dangerous about re-using my stock flywheel? I'd need new GM bolts right?
Old Dec 8, 2010 | 02:43 PM
jedblanks's Avatar
jedblanks
HTH
I definitely plan on changing the couplers, that's why I don't want to spend too much on the clutch. At one point in time people were having decent luck with the BMW couplers, is that still the case or if not what should I use?
Thanks to everyone for all the info...very informative.
Old Dec 8, 2010 | 03:10 PM
LoneStarFRC
Nothing particulary wrong at all with re-using your old flywheel. Any decent machine shop can give you an evaluation of it and the majority are suitable for surfacing, at least once. Especially since, as you say, you are not particularly hard on clutches to begin with.
You can reuse your old bolts. Just make sure the threads are clean and clear of any old thread-locker on them, including the threads in the crankshaft. Tip: acetone removes threadlocking compound. Fingernail polish remover is one good source for acetone if your missus has some around the house other wise most home improvement stores carry it. Me? I'm a big ARP fan, so I chose to use theirs.
Be sure to use fresh red locker when retorquing.
After reading a gazillion threads over the years on driveshaft couplers, I would tend to shy away from the BMW units. If you go with stockers, give either Gene Culley or Bob Wendorff a call as you'll likely get the best pricing on the GM units.
To Clutch
