Ron Davis Aluminum Radiators
Old Dec 8, 2010 | 05:24 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default Ron Davis Aluminum Radiators
Ron Davis Racing Products is responsible for cooling some of the world’s most competitive race cars. Designed for greater cooling capacity with lightweight performance, Ron Davis Racing Product’s radiators are made from the finest materials to produce the highest quality aluminum radiator on the market today.
  • Pressure testing at 32 psi insures each unit is leak free and structurally sound
  • CAD design and CNC sheet metal cutting is used that can hold .005" tolerance with complete repeatability
  • Metal grain is aligned during flat pattern CAD layout to insure maximum strength at bends
  • Furnace brazed cores insure leak free service for years and eliminates the need for epoxy, and aggressive fin counts for the application assure maximum cooling
  • Each core is annealed, and the tubes are welded seam, rather than brazed lock seams
  • The fins are multi-louvered for enhanced air turbulence to maximize heat rejection
  • Each weld is show car quality, with consistent bead width, dab spacing and penetration
  • Six Sigma Quality techniques pioneered in the aerospace industry are used to further prevent defects
  • Each process is analyzed scientifically for possible failures and they are prevented rather than being reworked
  • Major processes are mapped for consistent results and failure prevention analysis
Ron Davis Aluminum Radiator, 97-04 C5 $769.99 shipped
Old Dec 8, 2010 | 06:07 PM
Bill Dearborn's Avatar
Bill Dearborn
I had a Ron Davis radiator in my 97 and then moved it to my 03. Ran that radiator for 9 seasons with no issues. Great product and I highly recommend it.
However, when reading the description above I do have to ask what the hell does the statement "Each weld is show car quality" mean? To me that sounds like it looks good but doesn't say anything about how good it is.
Bill
Old Dec 9, 2010 | 01:13 PM
0HinsonSuperCars
Former Vendor
Bill
Great to hear
"Each weld is show car quality, with consistent bead width, dab spacing and penetration" I'm not sure what else you're looking for?
Seth
Old Jan 13, 2011 | 10:32 AM
0HinsonSuperCars
Former Vendor
Thanks for your orders!
To Ron Davis Aluminum Radiators
