battery being drained
Old Dec 12, 2010 | 04:41 PM
Black76's Avatar
Black76
Default battery being drained
I have a 99 manual and the battery is being dained dead .
i had a bad battery i replaced the battery now im getting hatch ajar warning and the battery is being drained how do i find whats draining the battery
Old Dec 12, 2010 | 04:47 PM
seoulbrooks's Avatar
seoulbrooks
Look at the hatch switch....its not adjusted correctly or bad and not turning off the light circuit.....
Old Dec 12, 2010 | 05:10 PM
markKlein's Avatar
markKlein
That sounds likely. Go out and look at the car in the dark, see if you can spot any lights (interior, glove box, under the hood etc.) on.
Old Dec 13, 2010 | 08:54 AM
Black76's Avatar
Black76
where is the hatch switch and how do you adjust it
Old Dec 13, 2010 | 10:44 AM
Black76's Avatar
Black76
but where is the hatch switch located and how do you check it ?
Old Dec 13, 2010 | 11:50 AM
jrose7004's Avatar
jrose7004
Make sure when you close your hatch that you have a door open. On mine the hatch looks shut but it's not. If I open a door it closes properly.
Old Dec 13, 2010 | 11:52 AM
Black76's Avatar
Black76
thanks i will but where is the hatch switch located and how is it adjusted
Old Dec 13, 2010 | 04:54 PM
seoulbrooks
I'm at work now and do not have access to the service manual. As soon as I get home I'll look it up and give you a cut and paste drawing. Some of the service manuals can be downloaded on line if you need one.
Old Dec 14, 2010 | 05:25 AM
seoulbrooks
the latches are under the panels on each side of the rear compartment. each latch has a switch and electrical connector.
if these are not adjusted correctly the rear compartment lights will remain on. Also check the strikers on the far outside edges of the hatch and make sure they are not missing or broken. if those lights are not staying on the rear latches are not the problem.
Latch Adjustment - Rear Lift Window Panel
Minor Adjustment
Loosen the latch mounting bolts.
Reposition the latch. Refer to Latch Replacement - Rear Lift Window Panel .
Major Adjustment
Loosen the latch bracket mounting bolts.
Reposition the bracket. Refer to Latch Bracket Replacement - Rear Lift Window Panel .
To battery being drained
