Clutch will not disengage??
Old Dec 12, 2010 | 05:20 PM
csilvers1984's Avatar
csilvers1984
Default Clutch will not disengage??
Had the car out awhile ago and upon launching the car the clutch is somehow stuck engaged...any ideas? I was considering replacing the clutch/flywheel along with slave/throwout. But the clutch only has around 5-7k miles and worked flawlessly before incident. Also will add that the pedal feels like I have full pedal pressure as before.
Spec 3+ with spec billet steel flywheel 5-7k
new slave throwout at same time
stock c5z MC.
Arp hardware
Any ideas on my problem??
Old Dec 12, 2010 | 05:23 PM
bartsky's Avatar
bartsky
Did you check fluid I would assume? Might try beeding if you have a remote bleeder installed, or do Ranger method from top. Some swear by Tick adjustable MC.
Old Dec 12, 2010 | 06:06 PM
lucky131969's Avatar
lucky131969
stock c5z MC.
Arp hardware
Hopefully you did not use ARP flywheel bolts.
Old Dec 12, 2010 | 06:11 PM
csilvers1984
Could this be a fuild problem?? It seems I have full pressure at the pedal . The resi is full and I did the ranger method about a month ago.
Old Dec 12, 2010 | 06:18 PM
csilvers1984
Yes it has arp flywheel bolts,the previous owner installed them.
Old Dec 12, 2010 | 06:22 PM
bartsky's Avatar
bartsky
What year Z? What gear did it stop in?
Old Dec 12, 2010 | 06:24 PM
lucky131969
There are reports of ARP flywheel bolts contacting the pressure plate on a SPEC 3 clutch. It will be interesting when you pull it apart, if you find that has happened.
Old Dec 12, 2010 | 06:39 PM
csilvers1984
Would it have started all at once if it was the flywheel bolts? Someone said they could back out or shear of it some cases. I just hate to replace the clutch being it's miles but I dunno we'll see.
And I was on the street done a 2nd gear launch (no tire heat) then attempted to heat the tires in 1st when the problem accured. I'm making 484/439 through 4.10s in a 03 z06. If anyone is wondering on the 2nd gear launch.
Old Dec 12, 2010 | 06:42 PM
lucky131969
No telling. Just bringing it to your attention. Your car....your call.
Old Dec 12, 2010 | 07:09 PM
csilvers1984
Yea I guess its tear down time here in a week or so,damn right when its cold as **** out haha
Old Dec 13, 2010 | 05:52 PM
ZZ06's Avatar
ZZ06
hmm full pedal pressure??.....fluid good?....high rpm launch?....lol sounds like you broke somthing. My PP got stuck on my car and i was 700miles away from home. My symptoms were similar. Hope you get to the bottom of it. Report back.
Old Dec 13, 2010 | 06:38 PM
racetchr's Avatar
racetchr
I doubt this is your problem but I'll share something that happened to me about a year ago. Same thing clutch would not disengage, but sometimes it would if you pumped the pedal. I thought it was obviously a mc problem until I took the clutch down and found I had a broken pressure plate It had a crack straight across the face of the plate and would release sometimes but not always. Weird.
Old Dec 13, 2010 | 09:20 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
ditch the spec and get a monster
Old Dec 13, 2010 | 09:30 PM
DIXZ's Avatar
DIXZ
My guess is a differential output shaft. Easy to diagnose...Jack the rear up and turn each wheel. If the opposite wheel doesn't turn, it is an output shaft.
Old Dec 13, 2010 | 09:46 PM
Carcass's Avatar
Carcass
The connection between this,and a non-disengaging clutch is going to have to be explained to me,'cause I'm just not seeing it....
Old Dec 13, 2010 | 11:46 PM
ZZ06's Avatar
ZZ06
i broke 2 of the fingers on my PP so it wasnt FULLY releasing
Old Dec 14, 2010 | 07:13 AM
CamminC5's Avatar
CamminC5
Old Dec 28, 2010 | 01:43 AM
csilvers1984
Alright guys this week I'll be tearing the car down. We had about 6in of snow so I'll be taking it to the inlaws in a few days. I'm going to pull everything to get diagnosis and then go from there. If it's a clutch needing replaced it will be a monster
To Clutch will not disengage??
