C6 shifter with C5 boot : O-ring size question
Old Dec 12, 2010 | 09:11 PM
MN-Brent's Avatar
MN-Brent
Default C6 shifter with C5 boot : O-ring size question
I'm doing the C6 shifter mod and ordered the shifter from Gene. Going to keep my C5Z pivot box for the solid bushings.
I am planning to re-use the C5 boot and see how it looks. For anyone that has used an O-ring to secure the C5 boot to the C6 shifter, do you recall the O-ring size you used?
Appreciate any reply.
B.
Old Dec 12, 2010 | 09:44 PM
Last C5's Avatar
Last C5
I've done several of these and I don't think an O ring is going to do what you want. I've been using a very small/thin tie wrap and it seems to work like a champ. (This $0.02 worth provided at no charge and worth about as much. )
Old Dec 12, 2010 | 09:49 PM
MN-Brent's Avatar
MN-Brent
I've read about that as well. Just wondering if the o-ring option provides a cleaner look than a possible zip tie lock bulge.
Maybe its small enough that you don't see it?
Old Dec 13, 2010 | 01:31 AM
Last C5's Avatar
Last C5
Tuck the zip tie joint up next to the seam on the boot and you'll never notice it. I think the O ring would flex and come off.
Old Dec 13, 2010 | 01:04 PM
chevy406's Avatar
chevy406
I didn't have to use an o-ring or a zip tie. I just trimmed the boot enough to where it would just barely slid on. Still using the same boot on my MGW shifter now.
To C6 shifter with C5 boot : O-ring size question
