Corvette Gods...What mods shall thy used?
I want a mainly street car that can run high 11s. Can i reach this with bolt ons?
Here are a few mods I was entertaining
- 4.10 diff
- LS6 or BBK Intake manifold
- SCT or Vararam Tuner
- Throttle body . which?
I like the idea of superchargers but looking for a cheaper option.
The BBK intake manifold is all Aluminum. It will heat soak as the motor gets hot. Your better off with composite LS6 manifold, or a composite FAST 102 or 92. You need a different throttle body all together with the FAST intakes. I however would not get into an intake manifold just yet. I would also hold off on the Throttle body at this point also.
The 410 gears is always a good idea.
Before I chose to break "into" my motor I did the following.....
I have the Vararam and am very happy with mine.
I would also look into a power duct.
http://www.westcoastcorvette.com/p-1...-04-c5z06.aspx
Full length headers is something you should do early on.
I have the LG Pro Long Tube headers and love them. They create a sound that's amazing. They run from the motor all the way back to your cat back exhaust.
Look into Cat back exhausts next. I have the GHL Bullets, and I sure wish I bought these first. I had multiple other exhausts, and the GHL Bullets are by far the best I have had on my car. Deep sounding and no drone. Best of both worlds! There is some good engineering behind these. Its tough to find a NEW exhaust for $850 that is any good. Best bang for the buck here.
http://forums.corvetteforum.com/c5-z...like-them.html
http://forums.corvetteforum.com/c5-g...l-exhaust.html
Next go to a tuner and get a GOOD dyno tune once the above mods are complete.
Once the above is complete, and you want more.... Start looking into either Heads/Cam setups, or Super charging, or Turbo charging.
This is basically the path I took. I later chose to go with Heads/Cam. I chose a Blower cam just in case I wanted to get a Super charger later on though...
Good luck with your choices !
Toque
The BBK and heat-soak concern is non-existent. Heat-soak is an issue with carb motors. The intake “soaks up” heat after shut down and when it is stated again the fuel hits the hot intake and affects the delivery.
The LS1 is obviously a fuel injected car and does not have this issue.
People also think that the intake will be hot and cause the intake air to be hot as well affecting performance, but I have not seen this as a concern. If you feel your LS1 intake after a long drive, it will be hot too. It’s not like it stays cool just because it plastic.
After a long drive I will pop the hood and place my hand on the intake, and so far I have never been burned nor has it felt unreasonably hot.
Another concern people have stated is that the warmer intake will heat the fuel cross-over tube and thereby increasing the fuel temp or causing vapor-lock. Well, the fuel tube has always been cold, not cool or warm, but cold to the touch after a long drive.
The LS6 intake is obviously a great intake, but if you are thinking about a BBK, please don’t be put off by those who haven’t used them.
Also, the aluminum will be a great choice if you decide to boost your motor. It can be ported and port matched as well.
For me though, in addition to the performance aspect, I also really liked the look of the intake.
Throttle body is not a bad idea, but probably not needed unless you do a cam swap or something that increases the high rpm demands.
If you do not want to turbo or super-charge your engine, then you will at least want to do a cam swap. Even a mild 22x @.050” cam can yield 50hp or more.
But, that being said, you already have the major bolt-ons, so a cam and good tune is definitely the next step for you. Doing a cam on these cars is fairly labor-intensive, but only due to the need to move the steering rack around. The actual engine work is pretty simple, and does not require removing the heads. Keep it reasonable and the valve train will be bullet-proof with just a spring upgrade. Right at 400 RWHP is easily obtainable with a very reliable/docile engine that has never had the heads off. Then get 3.90 gears and stock up on tires.
DG
I am running trick flow heads, 228/228 112ls cam and 125 shot of nitrous.
The nice thing about doing a cam is you can do other things while you are in there for cheap ( oil pump, double timing chain, bearings, lifters, push rods, underdrive pulley, rockers, etc) as I did.
Most of these things do not yield much extra power, but give piece of mind.
Any input on this cam?
