My car has a slight tune for the cold air intake, x-pipe and no mufflers. I have about 110,000 miles and would like to put a cam in it without doing anything to the trans/stall. Which cam would u recommend?
Sounds good...i appreciate it...i have a huge cam in my ram air and run 10's on motor all day long...but have a yank 4500 stall....my girlfriend drives this car sometimes and i just don want to put too much in this cruiser...
it'll be hard to tune it to prevent it from pushing through the stock converter at a stoplight but you can get it pretty close / acceptable... similar to mine, but I finally put a 3000 stall in it....
it'll be hard to tune it to prevent it from pushing through the stock converter at a stoplight but you can get it pretty close / acceptable... Similar to mine, but i finally put a 3000 stall in it....
Originally Posted by DANOTHEPIMP
thanks dank...ill keep that in mind....
Dano
A 224 or smaller would not be, those size cams are easily tunable with a stock stall.
