Check Engine Light with code P0128?
Old Apr 7, 2002 | 08:22 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Check Engine Light with code P0128?
Check Engine Light with code P0128 (10 PCM) - I used to get this before the head/cam package installation, now it's back. Anyone know what it means?
Old Apr 7, 2002 | 09:06 PM
GraveDigger's Avatar
GraveDigger
Default Re: Check Engine Light with code P0128? (JerryL)
Don't have that code in 2000 manual. P0125 is coolant. That is as close as I could find. :confused:
Old Apr 7, 2002 | 09:31 PM
rbocky2k's Avatar
rbocky2k
Default Re: Check Engine Light with code P0128? (GraveDigger)
I think it is a heated oxygen sensor code, but I don't know which side.
Old Apr 7, 2002 | 09:44 PM
alc2001's Avatar
alc2001
Jerry,
P0128 from my '01 manual:
"If the engine coolant fails to reach a preset target temperature before a calculated airflow is accumulated, P0128 will set."
"DTC P0128 is designed to detect a faulty thermostat."
It takes 2 successive drive cycles with a P0128 to set the MIL.
Hope this helps.
Alan
To Check Engine Light with code P0128?
