help with budget performance upgrades please
Old Dec 17, 2010 | 06:15 PM
carofmydreams's Avatar
carofmydreams
3rd Gear
Default help with budget performance upgrades please
i just came back form deployment and could finally afford the car of my dreams, a c5 targa, it came with a k&n intake c6 intake manifold and a bbk exhaust, i have about 1000 to play with, can someone suggest the best bang 4 my buck please
Old Dec 17, 2010 | 06:27 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I would make a plan first. A good set of headers would be one of
my first mod's, let your engine breath. Good luck.
Old Dec 17, 2010 | 06:35 PM
skyavonee's Avatar
skyavonee
I also vote for longtube headers if the car doesn't already have them. If you're patient you should be able to land a good used set for less than $800. After that I'd recommend a mail-order tune to take better advantage of your mods.
Old Dec 17, 2010 | 06:40 PM
SoDiezl350's Avatar
SoDiezl350
Nothing beats a wet nitrous kit in terms of bang for the buck power. If you want handling then C5 Z06 springs, C6 Z51 swaybars, and Bilstein shocks will give you a great upgrade and still leave you with a few hundred dollars in your pocket. For a 1000 you could also upgrade the seats in the car which is a huge upgrade imo.
Old Dec 18, 2010 | 12:07 PM
rebelheart's Avatar
rebelheart
Dump the k&n and install a Vararam!
Old Dec 18, 2010 | 08:45 PM
Cardinal Flyer's Avatar
Cardinal Flyer
Thanks for your service, and WELCOME BACK!
My 2cents:
Hold onto your grand, save another $500, and get a set of 410 gears if you have an MN6. Not sure what the cost is to improve gears on an auto, but gears are your best bet for dramatic SOP improvement.
Old Dec 18, 2010 | 10:17 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
you can get the chinese headers and street tune
Old Dec 19, 2010 | 12:19 AM
rebelheart's Avatar
rebelheart
Gears would make the most obvious improvement,but would prob eat up your whole grand.
Old Dec 19, 2010 | 07:41 AM
sfc rick's Avatar
sfc rick
1. Vararam and Power duct
2. LG Motorsports Long tube Streets (LG has a sale on) (JWMotoring.com has Military specials, just call to see)
Install in that order, and you should be close to your budget, if not wait till Uncle Sam drops another load.
Then plan on your next move for heads and cam down the road.
Old Dec 21, 2010 | 08:59 AM
carofmydreams
3rd Gear
its a 6 speed sir. do u still recommend the same gears?
Old Dec 21, 2010 | 09:29 AM
carofmydreams
3rd Gear
what gears do you recommend??
Old Dec 21, 2010 | 10:42 AM
skyavonee's Avatar
skyavonee
Waste of money.
Old Dec 21, 2010 | 12:33 PM
rebelheart's Avatar
rebelheart
Originally Posted by skyavonee
Waste of money.
Many owners and time slips would argue that point for sure.
Old Dec 21, 2010 | 12:48 PM
skyavonee's Avatar
skyavonee
The original question was about bang-for-the-buck. He already has an aftermarket low-restriction intake that draws cold air from under the nose. Any gains he'd see from the Vararam (or any other intake for that matter) would be minimal and thus his money best spent elsewhere. As always, IMHO.
Old Dec 21, 2010 | 12:52 PM
flynhi's Avatar
flynhi
Headers, X crossover and a tune should help.
See July 2010 Vette for header guide including Dynatech, American Racing, Bassani, BBK, Billy Boat/B&B, Borla, Pertronix, Exoticmuscle, and Kooks. I don't have a recommendation but ceramic coated headers will not heat up your engine bay as much as others. Also check on spark plug clearance.
Remember that long tube headers are most effective at higher RPM and some are designed to optimize HP there. So do your homework if you want torque for SOTP improvement at low RPM (stop light to stop light) as some headers are designed for a balance between TRQ and HP gains.
X crossover balances the back pressure on the engine side to side and doubles the exhaust crosssection aft of the X. If will also raise the exhaust sound an octave or two while quieting the exhaust somewhat and reduce popping during deceleration.
I bought a mail order tune from Ron Zimmer in LA a few years back that was very good.
Old Dec 21, 2010 | 02:50 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree to ditch the gears idea---mostly because with traction, lower gears will break parts on spirited drag race runs from a dead stop--
I would go as suggested with a set of LT's and X-pipe and deff. a tune--If you install the LT's without a tune you won't get the full benefit of them-- maybe even less !! But tuned you can get up to 20-30 more RWHP--- (if in your state you can get past the smog police)
To help with budget performance upgrades please
