I recently bought a "New" Z06 Canadian Cluster with 0 mile on it (what seller said).
Before to swap these clusters I want to be sure that the mileage is at 0.
May I do that on my workbench or is it only possible once connected in the car ?
Thanks for your help
jm
jm
Unless you have the specific equipment(or know a shop) that can interface with the IPC, you'll have to plug it into the car.
Ah and it will display the cluster's odometer not the car one ?
There is no possibilities to power directly the pins on the back ?
The car odometer is recorded on the IPC. So if you want your cars mileage to match, you have to swap that board from your old IPC. There is a thread that describes this if you search. Power up the IPC? Is it possible, yes, have I done it.....no. The last thing you want to do, is hook up something wrong, and damage the new cluster you have.
