Changing motor mounts, how difficult?
Dec 22, 2010 | 05:58 PM
I'm wanting to install new motor mounts and want to know what all is involved in the replacement.
What needs to be removed, etc.
I imagine that I am not just gonna be able to jack up the engine and replace 'em, huh???
Thanks in advance
Dec 22, 2010 | 06:02 PM
Quote:
Originally Posted by
manley845
Thanks in advance
I'm also doing this, someone please chime in.
Dec 22, 2010 | 06:21 PM
MyEBc5Z
PM sent.
Dec 22, 2010 | 08:00 PM
Cruise-In VI Veteran
St. Jude Donor '12
I took the nuts off the bottom of the mounts, then GENTLY jacked up on the motor with a big 2x6 board.
This let me loosen the mounts to the block. You can do it, even w/ the headers on the car.
Dec 22, 2010 | 09:44 PM
why would you want to change out the motor mounts?
Dec 22, 2010 | 11:22 PM
C5kid
Did you have to unhook your x pipe from the headers?
Dec 23, 2010 | 12:05 PM
m6 c5
Good question!
memphis_vette
Because they're worn would be most peoples assumption, but I want to install solid mounts.
I'll install an Energy Suspension diff mount next, then control arm bushings, etc etc etc
Dec 23, 2010 | 01:18 PM
St. Jude Donor '12
m6 c5
No, your only jacking it up maybe 3/8" - 1/2"
Then you remove the mounts from the block, this gives you all kinds of room to slide new ones in.
Dec 23, 2010 | 02:04 PM
C5kid
Sweet, I think I'm gonna order my mounts this week and install them my self.
Dec 23, 2010 | 08:57 PM
manley845
Im looking at doing the same thing.
c1 ,
c3 ,
c5 ,
change ,
changing ,
corvette ,
difficult ,
engine ,
hard ,
install ,
motor ,
mount ,
mounts ,
replace ,
replacing
