Timing
Old Apr 8, 2002 | 09:19 AM
shftn6's Avatar
shftn6
Default Timing
What should your timing be at WOT? What would it mean if your timing dropped off when you hit WOT?
Old Apr 8, 2002 | 11:01 AM
C5 YA's Avatar
C5 YA
Default Re: Timing (shftn6)
Timing will depend on a couple of things. It depends what year C5 you have. It depends whether or not there was any detonation. It depends on Intake Air Temp. It depends on allot of things. But if your timing fell @ WOT, I would say detonation and then your timing was pulled by the PCM. But that's just a guess. Timing varies from car to car. It depends on the car mods & type of fuel being used.
I currently see 31 on my 99 C5 @ WOT w/ no detonation.
Old Apr 8, 2002 | 11:03 AM
shftn6's Avatar
shftn6
Default Re: Timing (C5 YA)
How do you know if you have detonation?
Old Apr 8, 2002 | 11:48 AM
NineBall's Avatar
NineBall
For your engine setup, I'd say that 28+ degrees timing at WOT would be the best. If it is dropping off, you could be getting knock retard (real or false KR). Are you using Autotap to monitor the timing?
Tony
Old Apr 8, 2002 | 12:10 PM
shftn6's Avatar
shftn6
Default Re: Timing (NineBall)
Yes I am using Autotap and I show on all my files to be around 28. I had my car dyno'd on Friday (first time since my H&C install) and it was 290hp. A loss of 25 hp from before my work. The guy running the dyno said my car is losing timing.
Old Apr 8, 2002 | 12:14 PM
shftn6's Avatar
shftn6
Also not getting any KR. All were under 1 at WOT.
Old Apr 23, 2002 | 12:13 AM
C5Noir's Avatar
C5Noir
Were you getting any knockretard? 290HP is EXTREMELY low for your mods. You should be at over 400 RWHP
Old Apr 23, 2002 | 12:14 AM
C5Noir's Avatar
C5Noir
What was your A/F on the dyno?
Old Apr 23, 2002 | 12:38 PM
BubbleHead's Avatar
BubbleHead
Default Re: Timing (C5Noir)
shftn6 had a bad cat, which is what restricted his exhaust and dyno numbers. With gutted cats, we pulled 380 RWHP with stock programming.
It's amazing what a bad cat can do to your horsepower. Something to keep in mind if someone else runs into a problem like this one.
To Timing
