Transmissions
Old Dec 24, 2010 | 08:41 PM
-Fidanza-'s Avatar
-Fidanza-
Default Transmissions
I'm running high 400's hp range to the wheels, have 4.10 gears and a DTE stage III Rear end. I am looking to fix my trans cause the Syncro's are going. Should I go to thegearbox.org and build it myself or go with a pre made? What's the better deal? I would like some opinions, thanks guys!
-Mike
Old Dec 24, 2010 | 10:49 PM
Paul 75 L82's Avatar
Paul 75 L82
I bought a new GM trans when I did mine. But most of the guys use RPM.
Old Dec 25, 2010 | 12:14 AM
99 vett babycar's Avatar
99 vett babycar
if you're up to it, build it yourself. If not, call the guys at RPM.
Old Dec 25, 2010 | 11:19 AM
ZZOOM06's Avatar
ZZOOM06
I bought all the good parts from the gearbox and had my local friend do the rebuild for me. Saved a ton of money and it's been flawlwss ever since.
Jimbo
Old Dec 25, 2010 | 11:43 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Is RPM the best A4 trans for 600rwhp. Is there anyone else that builds a great trans?
Old Dec 25, 2010 | 11:50 AM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I have an RPM IV A4, which is rated for 500 RWHP and very satisfied. I believe DTE is also considered a reputable transmission builder.
Old Dec 25, 2010 | 11:53 AM
Pewter1's Avatar
Pewter1
If you are in Indiana, and you don't use RPM........I will read your post when you are taking it to them later........Rodney, at RPM has the best vette knowledge on our cars driveline than anyone else! Great company to do business with! You go there and can see them do what they do, and fast!
Old Dec 25, 2010 | 11:56 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I'm thinking of the level V, just bought an A&A kit and hoping to hit 600hp. How do you like the way it shifts, is it nice and hard under WOT?
The cool thing about RMP is that they are 80 miles from me,
Old Dec 25, 2010 | 11:58 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I've heard good things about them, I am just doing my homework before I drop 2k+ I will most likely go with there level V! Thanks for the advice
Old Dec 25, 2010 | 12:05 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Will I need a tune after new trans?
Old Dec 25, 2010 | 04:08 PM
ragtopws6's Avatar
ragtopws6
-Mike
If you are mechanically inclined and have the correct tools, you can do it yourself. You will need some special tools but if you're doing this one time, the cost of the tools will not offset the savings of doing it yourself. If you don't want to tackle it yourself, I would highly recommend RPM Transmissions. Great customer service, knowledgeable and most of all a supporting vendor of Vette forum.
Old Dec 25, 2010 | 04:47 PM
tom01ss's Avatar
0tom01ss
Former Vendor
i can build both auto and manual both are super easy to do. let me know
Old Dec 25, 2010 | 05:24 PM
Dope's Avatar
Dope
Resident moron
I'll say it again. RPM. Don't waste your time or money elsewhere.
Dope
Old Dec 25, 2010 | 10:28 PM
Optimus_C5's Avatar
Optimus_C5
St. Jude Donor '12
Love the way it shifts. Very firm! At 1/2 throttle it chirps the tires when it shifts into 2nd. At full throttle when it shifts it triggers active handling. I do have a Yank SS3200 converter, RPM 3:42 gears and did have my tuner adjust the shift points and firmness after the install.
RPM 80 miles away = Go to RPM and get the Level V!
Old Dec 25, 2010 | 10:34 PM
Optimus_C5's Avatar
Optimus_C5
St. Jude Donor '12
If your just doing a tranny swap and nothing else then no tune is necessary. You will, probably want to have the shift firmness set to your personal preference.
Old Dec 26, 2010 | 06:09 PM
J.R.'s Avatar
J.R.
RPM Rocks.
Old Dec 26, 2010 | 07:32 PM
LoneStarFRC's Avatar
LoneStarFRC
For a 6 speed? Not for the OP. Maybe Blitzkrieg.
Btw. ditto on RPM!
To Transmissions
Old Dec 27, 2010 | 02:08 PM
TurboTnZ06's Avatar
TurboTnZ06
RPM Level V made my Z06 fun to drive again. Haven't missed a shift or popped out of gear since the upgrade!
Old Dec 27, 2010 | 09:29 PM
-Fidanza-'s Avatar
-Fidanza-
How much difference is there between 4 and 5??
Old Dec 28, 2010 | 09:09 PM
Optimus_C5's Avatar
Optimus_C5
St. Jude Donor '12
Btw. ditto on RPM!
Yes not necessary on a MN6 for the OP, Correct on Blitzkrieg.
Sorry for contributing to a hijack. Thought I was responding to the OP.
