LG Coilover install..
Old Jan 2, 2011 | 02:20 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by narfdanarf
My suspension is set to max stiffness (12?) cause I was worried about slamming the wheel into the fender. I will call Anthony Monday thanks!
I was also a little worried if maybe my sway bar/endlinks are hitting something cause I'm so low, but if you haven't noticed anything like that either than it's probably just my top hats coming apart.
I have not noticed anything like your describing. Don't get frustrated. You will get it done...
Toque
Old Jan 7, 2011 | 10:55 AM
BitViper's Avatar
BitViper
More info iin a diffrennt thread..
http://forums.corvetteforum.com/c5-t...k-my-butt.html
Old Jan 8, 2011 | 10:30 AM
FLYNAVY30's Avatar
FLYNAVY30
hey, dont mean to hijack your thread but since it sounds like we're both doing this at the same time, had a question for you or any of the others....
how did you guys loosen up the mounting tabs at the bottom of the front assemblies where the two bolts go? I know they're supposed to rotate freely so that you can line them up with the holes in the A-arms, but I cant get mine to rotate to save my life.
Old Jan 8, 2011 | 10:37 AM
Slow Z06's Avatar
Slow Z06
Stick a screwdriver in the hole and twist it.
Old Jan 8, 2011 | 12:01 PM
BitViper's Avatar
BitViper
Ahhh I wish I could... I havent started mine yet.. so Im learning from you
Go Navy!
Old Jan 8, 2011 | 12:07 PM
FLYNAVY30's Avatar
FLYNAVY30
well, so far Ive tried a screw driver, c-clamping them to a workbench and rotating the assembly, and finally, installing the two bolts with a metal rod connecting them and whacking it with a rubber mallet a few times....still no dice
Old Jan 8, 2011 | 05:00 PM
BitViper's Avatar
BitViper
Mann.. I juxst went out and tried min (still in the box) they rotated just fine.. one was stiffer than the other but both rotated
Old Jan 9, 2011 | 11:28 AM
FLYNAVY30's Avatar
FLYNAVY30
ended up bolting mine as they were to the lower A arm, lubing the bearing up pretty good with some WD40 and then kicking the assembly until it rotated in to the point where I could line it up. Not terribly precise or scientific, but sometimes you just need a bigger hammer!
Old Feb 16, 2011 | 12:45 PM
BitViper's Avatar
BitViper
Just wanted to capture all the other discussions going on with this
and
http://forums.corvetteforum.com/c5-t...oil-overs.html
Old Mar 20, 2011 | 12:15 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I finished the install today with a buddy's help and to be honest, I am so freakin lost on setting these up I am almost to the point where I am going to go back to stock. Oh wait...my springs are sold and shipped.
Frustration isn't even the word I feel right now. I have been adjusting and readjusting and my car has NOT moved!
I think a good night's rest will help calm me down and I will get back out there and adjust things again. I think I know what I did wrong.
Old Mar 20, 2011 | 07:51 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Well, I got things where they need to be. I will need to come down a little in the front to close up the gap, but over all, the car is sitting much higher and in a much better position.
Thanks to my buddies Vinnie and Steve for helping out. Here is my post on my install in the C5 ZO6 DISCUSSION forum...
http://forums.corvetteforum.com/c5-z...post1577113214
Micah
