Loud clicking coming from engine, rough idle :( :( :(
Old Dec 28, 2010 | 03:05 PM
skyavonee's Avatar
skyavonee
Originally Posted by lucky131969
Uggggh.....maybe it's a tumor........stop that.
No reason for this
I asked a specific question, "Is your oil pressure normal?". If the answer to this question is "Yes" then obviously the rest of my post can be ignored. If the answer is "No" then it should be looked into.
Here's the thread I referenced.
c5-z06-discussion/2743141-loud-ticking-after-cam-install-and-etc.html
Old Dec 28, 2010 | 04:49 PM
SpeedyRCM_TX's Avatar
SpeedyRCM_TX
Thanks everyone for the help so far. I'm about to head home and can get under the hood to figure this out.
Question, am I ok to start the car up again and let it idle to try to pinpoint the noise for just a minute or two? I really don't want to do any additional damage...
Old Dec 28, 2010 | 06:13 PM
SpeedyRCM_TX
Only current code is a P0106
Old Dec 28, 2010 | 06:26 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
P0106 -Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
Old Dec 28, 2010 | 06:27 PM
SpeedyRCM_TX
How do I fix it Mr. Smarty-pants
Old Dec 28, 2010 | 06:40 PM
mojo1's Avatar
mojo1
englandgreen hot line
Old Dec 28, 2010 | 06:55 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't see how a MAP issue could cause "clicking" noises. Before going crazy, and assuming the worst, I'd look for a plug wire shorting against a metal part on the engine, especially if the car was idling when it first appeared.The ignition arcing makes a sound that could be described as "clicking"...
Old Dec 28, 2010 | 07:30 PM
mojo1's Avatar
mojo1
whats the word mang??????????????????????????????
Old Dec 28, 2010 | 07:46 PM
SpeedyRCM_TX
I'm thinking the noise is valve train noise. It's hard to pinpoint where the noise is coming from with the engine running, and the exhaust rumbling, and the fan belt turning.
Old Dec 28, 2010 | 10:02 PM
Pack Leader's Avatar
Pack Leader
Pull all the plugs & do a quick compression test. Look for a low cylinder then pull that valve cover. Probably a spring.
Old Dec 28, 2010 | 10:58 PM
Jnape's Avatar
Jnape
Hell, it is faster to just pull the valve covers than the plugs.
Old Dec 29, 2010 | 01:59 AM
NatB's Avatar
NatB
Hope you have resolved your issue.
If it were my car, I would have it TOWED (DO NOT START ENGINE) to a good shop. I would not mess with blowing the engine .
Valve springs are cheap- even if you pay someone $600-$800. Compared to a new engine.
Best of Luck !
Old Dec 29, 2010 | 08:06 AM
  #33
SpeedyRCM_TX
Car is still parked in my garage, broken...
Should get it towed out to EnglandGreen either this week or next.
Old Dec 29, 2010 | 09:37 AM
  #34
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Any loud clicking, tapping, knocking and etc...do not start up the engine till you've repaired the issue. Either have it towed to the place of your choice or pull the valve covers to look at the springs.
Old Dec 30, 2010 | 10:58 PM
  #35
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
There are a lot of people on the north side of Houston. Have someone that knows about Vettes stop by and look at it. I would do that before I spent the money on a tow bill.
Old Jan 4, 2011 | 02:40 PM
  #36
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Broken valve spring.
Old Jan 4, 2011 | 02:48 PM
  #37
lucky131969's Avatar
lucky131969
Is that what you guys found Stephen? If so, what springs are you upgrading to?
To Loud clicking coming from engine, rough idle :( :( :(
Old Jan 4, 2011 | 03:32 PM
  #38
SpeedyRCM_TX
Geico emergency roadside service took car of half the tow bill. It was a broken valve spring...
Ordered my Mayhem kit today... I'm so giddy
Old Jan 4, 2011 | 05:28 PM
  #39
bartsky's Avatar
bartsky
Wow! That really sucks, as I use to own this car. I would be certain it had upgraded springs in it with the cam that was installed. Let us know what springs it had in it.
PS
I still miss that car!
Old Jan 4, 2011 | 05:52 PM
  #40
Atok's Avatar
Atok
Well that sucks, but fairly easy fix most times.
This is an '02 Z06 correct? How many miles on those springs?
