I was checking out a friend's new S2000, and I noticed that I couldn't get into reverse gear with the ignition off. He said that was true off all manuals and I thought :bs , so I got in my car and :confused: - I couldn't get into reverse either! Strange I never noticed it before, but anyone know WHY? We couldn't think of any good reason. You can select any of the forward gears.
:bs
The only thing is it is tough to get it in reverse sometimes, car running or not. That's probably what you noticed. :seeya
Ok, I had to run out to the car and test this again. I can't get it into reverse (pushing right past the 5th & 6th line). I put the key in and twist to run (without starting the motor) and BAM I'm in reverse. Pull the key, and no reverse. There's gotta be some kind of lockout for reverse or I'm going :crazy: ...
The C5 has a reverse lock-out solinoid, which prevents selection of R if the car is moving faster than 2 MPH. Since the solinoid needs +12V to allow reverse selection, it will be blocked when the engine is off. Most cars do not have this, and they are difficult to get into reverse only because the gears are at a standstill (with the engine off), as they are typically not syncromesh. The C5 needs this lockout because the R is so near 5th.
Thanks for the info! I don't know why it was bugging me so much. Not like I really need to shift into reverse with the engine off... I even went down to a nearby car dealer during lunch to test drive a Z3 just to see if it did the same thing. In case anyone cares, it doesn't. Although, it took some effort to get it into reverse... and I don't really like how it's next to 1st. I could see someone slamming into the car behind them from a stop if they're in a hurry!
