Hello guy, im looking to put a external B&M transmission cooler on my vette when i do the transmission install...I wanted to use the stock transmission lines that go to the radiator, I wanted to basicaly have an adapter from the stock transmission lines to -6, -6 to cooler and out -6 and return to the return line. mounting it behind the duct for the passanger fog light. i would like to make it clean and use the correct adapters to do so. I tried finding out the fittings but no luck...
Dont want to run new lines bcz ones that are on there are in great shape and arent rotted or anything at all, so i dont find a need to spend on all an lines and setup..
I havent pulled the transmission lines out from the radiator, as i am on vacation, Anyone know what the stock transmission ends are that thread into the radiator?
