Throttle Body Bypass
Old Apr 8, 2002 | 05:10 PM
geoc's Avatar
geoc
Default Throttle Body Bypass
I am trying to install a Throtle Body Bypass tube but can't get to the short hose under the throtle body with pliers. Anyone ever cut this hose to do it.
Old Apr 9, 2002 | 12:47 AM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Throttle Body Bypass (geoc)
You need to remove your air duct to gain room to get your pliers in there.
Old Apr 9, 2002 | 10:50 PM
gbm's Avatar
gbm
as stated, remove the air duct (2 mins) to get to this; after that it's pretty simple. Without doing it, it's almost impossible. :cheers:
Old Apr 10, 2002 | 12:30 AM
Jerryk's Avatar
Jerryk
This Mod is a waste of time, I did it than returned it back to stock. Did not like the look and could not see any gain. some things dont do much even if the seller says it does but each to their own :yesnod:
Old Apr 10, 2002 | 12:50 AM
psychokiller's Avatar
psychokiller
Default Re: Throttle Body Bypass (Jerryk)
:bs
Old Apr 10, 2002 | 08:07 AM
vette.se's Avatar
vette.se
Remove the airduct to get to it.
I would replace the 'kit' with a $2 hose from the engine to the radiator.
:cheers:
Old Apr 10, 2002 | 10:42 AM
RyanC7's Avatar
RyanC7
yep is a gimick mod.......waste of time........
:seeya
Old Apr 10, 2002 | 03:13 PM
Scruffy's Avatar
Scruffy
Default Re: Throttle Body Bypass (Ryan2002C5)
As others have said. This is a waste of time/money. TB by-pass = :bs
Old Apr 10, 2002 | 03:18 PM
gbm's Avatar
gbm
Default Re: Throttle Body Bypass (Scruffy)
if it get's you even a pony or two, what the f? :sleep:
Old Apr 10, 2002 | 03:44 PM
Horsepower's Avatar
Horsepower
Default Re: Throttle Body Bypass (gbm)
I don't beleive that this mod will gain you any hp. However, I do beleive that it could save you from losing some horses in certain situations. In these situations you will probably not even notice one way or the other. I consider it in the same class as a lower temp t-stat. The other day when my car was all heatsoaked I dynoed it and lost a few ponies to knock retard. I beleive anything I could have done to keep things cooler would have helped prevent that. As far as the kit, ya it's bs, but some people don't want to waste the time trying to find the proper fitting pieces and would rather just pay a few bucks. jmho
Old Apr 10, 2002 | 08:03 PM
Jerryk's Avatar
Jerryk
Default Re: Throttle Body Bypass (seanr)
I tryed this you have two different sizes, a hose did not work out as one side was real tight and the other was way loose and had to really tighten the hose clamp down to make it stop leaking. I put it back to stock (waste of time) :cuss
To Throttle Body Bypass
