2000 Coupe Most cost effective mods
1. Air Intake System
2. Longtubes/X-pipe/Cat-back
Then the next steps rely on which path you want to take with your Vette whether it's F/I or N/A. Judging from your OP, it sounds like you're leaning towards N/A. In that case I would do it in this order:
1. Cam
2. Intake Manifold w/ TB
3. Heads
It would be wise to just have everything installed at the same time to save work. Kooks, LG, and American Racing make amazing headers. Cat-back would really just be your choice in sound. I myself have Borla Stinger's and could not be happier; Corsa, B&B bullets, and GHL Bullets are also some popular choices. For the cam, you need to do some research on. It all depends on how big you want to go. I saw that you noted you want to keep driveability, so I would recommended a medium-large cam for most power and a nice lope but with a good tune easy DD ability, some popular choices are the G5X3, and MS3 cams. Those are decently large cams and need to have a good tune to have good driveability but put down great numbers; you really need to do research to find what best fits your needs. The intake manifold is an important mod as are heads when doing a cam. The Fast 90mm intake manifold I believe has been discontinued but they are still out there being sold from many vendors. The new FAST 102mm will fit but you will have to do some shaving to clear the stock cowl. The LS6 is of course another option that will always be around. Do not forget to pick up a TB when picking up an intake manifold; a popular option is the LS2 TB with a harness adapter for the LS1. For Heads, it all depends on what you wish to spend. AFR, and Trickflow are popular but are also a bit expensive (you do get what you pay for). Many like going with PRC or Patriot Heads because they flow very well and have proven themselves for results plus they will save you some money if you are on a budget. One mod that I would recommend are gears. You will get a decent bump in performance and big SOTP improvement if you make a swap. Since you are going H/C/I, I would recommend 3.73's but 3.90's would be a great option too if you wish to gear it more aggressive. DTE offers built differentials that are direct bolt in's but cost a little bit of money. Suspension mods are always great. For what it is worth, the C5 Z06 suspension is really an amazing setup and can be cheap if you do some looking around in the FS section of the forum.
The main key for building these Vette's is combination. You have to know you what your goals are realistically and you have to plan accordingly. H/C/I builds can be very driveable if you piece together a great combination and have a great tuner. Research is very important and reading on this forum can do nothing but help you gain knowledge. My advice: be patient, take your time, do research, listen, learn, set realistic goals, and be open minded. In the end, if you do this, you will be more than happy with your Vette. Good luck and Happy Holidays!
There are some interesting gear charts here in the forum, comparing all the gear ratios of the trannys and the diffs, do a quick search.
DG
lol. Thanks for pointing that out. I went ahead and edited the post. (I actually wrote this nearing the very end of my work day; 11:30pm to 10:30 am so I was pretty tired) Thanks for looking out!
DG
