Headlight Motor Problem
Old Dec 29, 2010 | 09:45 AM
SigsC5's Avatar
SigsC5
Default Headlight Motor Problem
I have an 04 C5 it was in an accident and broke my drivers side headlight motor. I just replaced it with a used one. Now when I turn on the lights the passenger side goes up but not the drivers side. Then if I turn off the lights the passenger goes down and the drivers goes up. I've tried to manual turn the drivers side down to match the passenger side but when I turn them on again it does the same thing. Help mixed up lights!!!!!!!!!!
Old Dec 29, 2010 | 10:53 AM
LoneStarFRC's Avatar
LoneStarFRC
Try disconnecting the bellcrank arm, manually rotate the motor in the opposite direction 180* and re-attach bellcrank arm.
HTH
Old Dec 29, 2010 | 11:19 AM
SigsC5's Avatar
SigsC5
I have tried that but I will definitely try again. Could I have the pivot arm hooked up wrong on the motor? If so does any one have a picture of how it hooks to the motor.
Old Dec 29, 2010 | 02:28 PM
LoneStarFRC
By "pivot arm" are you referring to the arm that connects directly to the motor itself? If so, it only connects to the shaft of the motor in two possible, ways since the hole in the arm (bellcrank) is a "double-d" configuration, and that is the arm I am referring to.
That arm also has an offset bend, or "dog leg" to it, and if it were flipped over incorrectly, I don't think the other end would reach, plus I think the arm would hit part of the mechanism and not move freely.
Old Dec 29, 2010 | 02:40 PM
87SAM's Avatar
87SAM
It is possible to attach the arm to the motor with the “elbow” pointing in the wrong direction. Not sure this would cause the problems the OP is experiencing but it does restrict the movement range.
Old Dec 29, 2010 | 02:53 PM
LoneStarFRC
I'm thinking..........
Old Dec 29, 2010 | 05:04 PM
SigsC5's Avatar
SigsC5
Yes I am referring to that arm that hooks directly to the motor. You are right it can fit either way but the mechanism hits the stops and won't move. So it can only fit correctly one way. I have tried turning the motor 180 degrees and more and nothing seems to make any difference. Still puzzled any more ideas or am I maybe doing something wrong?
Old Dec 29, 2010 | 07:59 PM
LoneStarFRC
I think I remember seeing a TSB regarding the driver's side headlight motor mounting. I can't recall exactly what year(s) it applies to, but I think it was the '02s (maybe later years as well?). The fix involved nothing more than adding three washers to the mounting bolts of the motor to position it (and it's attached bell-crank arm) further away from the frame. If memory serves, what was happening was, because of the mounting position of the motor (too far to one side), the bell-crank was rotating around and not making contact with the nylon stop pads and traveling much too far. Try a search.
There's also the early style/late style motors to consider too. As far as I know, the only difference is the main drive-gear cover and the way it's attached. I don't think there is any other difference, but I could be wrong. There are of course differences in right side/left side motors, but I don't think a right side will even mount on the left.
Food for thought.
Try a search.
Old Dec 29, 2010 | 08:28 PM
LoneStarFRC
Found this:
http://forums.corvetteforum.com/c5-t...r-problem.html
Even if this not your specific problem, it doesn't hurt good to be aware of.
Old Dec 29, 2010 | 10:29 PM
Cratecruncher's Avatar
Cratecruncher
I'd take off bezzles on both sides of the car and manually raise and lower the lights to convince myself the linkages are operating identically. If it's not the linkage doing something bizarre it must be electrical.
When the headlights are raised the headlight module sends positive voltage to one wire of the motor and grounds the other. When the lights are lowered the opposite occurs. The OP said his car was in an accident. If the new (used) motor was for some reason spliced into the existing wiring it's possible the motors wires are just backward.
Old Dec 29, 2010 | 10:38 PM
LoneStarFRC
Good idea to check for any wiring repair issues.
Old Dec 29, 2010 | 11:02 PM
SigsC5's Avatar
SigsC5
thanks guys. I read the article about the headlight motor needing washers to move the motor back so the arm will hit the stops. This could definitely be the problem and I will try but mine does not go down then come back up half way like those guys said theirs did. Mine just go opposite of each other when passenger is up with light on drivers side is down with light on. When drivers side goes up light goes off and passengers side goes down like it should with light off. Could this still be the arm not hitting the stops correctly so the motor does not do what its suppose to do. Still baffled?
Old Dec 29, 2010 | 11:09 PM
SigsC5's Avatar
SigsC5
I don't think it would be a wiring problem when the car was in the accident it was not hit hard enough to do hardly any damage. Everything works with the headlight coming on and off. I will sure check.
Old Dec 30, 2010 | 12:17 AM
Carcass's Avatar
Carcass
My old school thinking tells me the 2 wires to the motor are reversed-possibly installed into the "molex" connector in the wrong spots when the assembly was manufactured.
IF it were mine,I'd switch the 2 wires and see what happens .
Check this: the green wire to the headlight motor should be the outermost wire on the wide connector that plugs into the loom on the top of the frame rail,and the gray wire should be the second one in (both sides,driver and passenger)
Check the location of the green wire on the side that works correctly,see if it's position matches the green wire position on the replacement.
If these wires are reversed on your new motor,there's your problem-and you need to switch 'em.
And good luck
Old Dec 30, 2010 | 09:17 AM
SigsC5's Avatar
SigsC5
I just checked my wires and the gray and green one have been switched. They are not in the same position as the passenger side wires just as Carcass suggested. Now what tool do I need to get the prongs out of the gray plug and switch them. Don't want to damage them!!!!!! Thanks
Old Dec 30, 2010 | 10:01 AM
SigsC5's Avatar
SigsC5
I just switched the wires and everything works perfectly. Thanks to everyone who helped.
To Headlight Motor Problem
