Cam ?
Old Dec 31, 2010 | 12:04 AM
atmsrus1's Avatar
atmsrus1
Default Cam ?
Would a cam from a LS6 Z06 work in a 2001 LS1 Coupe and if so would the benifits be worth the swap.
Thanks,
Russell
Old Dec 31, 2010 | 12:06 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Yes it will fit and no its not worth it. If you are going to take the time to do a cam swap put something bigger in. The gains from a LS6 cam will be very very small VS an aftermarket cam
Old Dec 31, 2010 | 12:43 AM
atmsrus1's Avatar
atmsrus1
Thanks that is just what I needed to know. I would like to have something a little more than stock but since I don't track my car I don't need something that sounds like the car is about to stall.
Russell
Old Dec 31, 2010 | 02:02 AM
0331MARINE's Avatar
0331MARINE
Russell
Go with a 224/228 on a 113/114LSA
Old Dec 31, 2010 | 02:27 AM
rkboz's Avatar
rkboz
Some people put a big lift long duration cam in just for the lope sound. There is the high rpm high hp school of thought or something else to think about. What about a cam that makes low end torque and mid range hp. High rpms usually kill motors, what if you had a low end torque monster and had a flat torque curve out to about 5800 rpm. You would stay out of the kill zone and have very usable torque where you need it.......just say'n.
Old Dec 31, 2010 | 04:52 AM
zeevette's Avatar
zeevette
It's all about the combo. What are your current mods, and transmission type? Also rear gear ratio? The '02-4 Z cam is bigger than the '01, BTW.
Old Dec 31, 2010 | 10:17 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks,
Russell
Yes it it will, it's a very good cam but you will also need to replace the valve springs and some minor tuning to the PCM.
Old Dec 31, 2010 | 10:49 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Learned this from Don Kinder years ago, this is a great grind for 90% of the C5's
Old Dec 31, 2010 | 05:20 PM
atmsrus1's Avatar
atmsrus1
Thanks for the advice....the only mods I have is a Blackwing and I am about to put some headers on. It is a 6 speed with the factory gears I assume.
Thanks again,
Russell
Old Dec 31, 2010 | 05:22 PM
atmsrus1's Avatar
atmsrus1
Would this work with the stock heads or would I need to replace the heads?
Russell
Old Dec 31, 2010 | 07:02 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Russell
It will fit without replacing the cylinder heads, however you will absolutely need different valve springs, push rods and a significant amount of PCM re-programming (tunning).
The OEM cylinder heads and valve train are designed for a maximum of .550" of lift. Any cam with valve lift above that is a waste on stock cylinder heads and sacrifices reliabilty.
Old Dec 31, 2010 | 09:45 PM
Blow Torch's Avatar
Blow Torch
Old Dec 31, 2010 | 10:41 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Originally Posted by Blow Torch
Perhaps you should take the time to read Will Handzell's book on modifying and tuning GEN III engines.
Old Dec 31, 2010 | 10:52 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
With MUCH help from several CF members, my car just got a 228 230 585 588 113 lsa cam along with PG dual springs, etc. and a dyno tune.
TQ is awesome from 2000 thru 5500. Idle set at 850 and with my MN6, no drivability issues. Sounds SWEET too!
Other mods: VRB2, LT Hdrs and HF catback.
OP,
If you are going to all the trouble of a cam swap,,,go bigger than a stock Z06 cam!
my $00.02
Old Dec 31, 2010 | 11:00 PM
0331MARINE's Avatar
0331MARINE
Russell
You will be fine with the heads. Check out Texas-Speed.com. They have great cam kits. I got my MS3 kit from them a few years ago and its still running strong. My car is 420RWP on stock 241 heads.....
Old Jan 1, 2011 | 10:41 PM
atmsrus1's Avatar
atmsrus1
Thanks I appreciate it. Thanks to all for the info and suggestions, been a long long time since I have torn into a motor.
Russell
Old Jan 2, 2011 | 12:01 AM
RogerT's Avatar
RogerT
What cam duration and lift are you talking about?
Roger T
Old Jan 2, 2011 | 02:10 AM
KBL's Avatar
KBL
Even on an engine with a maggie?
Old Jan 2, 2011 | 08:00 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Russell
Check out the ECS blower cam, or the LG Executive cam, Both are great cams, I have the ECS cam in my A4 and it idles nice at 575 rpms, They really do there job in the mid-high rpm ranges! go to you tube and listen to some of the cams!
To Cam ?
