Changing the fuel pump on a 97 coupe
Old Dec 31, 2010 | 06:38 PM
OpethMike's Avatar
OpethMike
Default Changing the fuel pump on a 97 coupe
I'm finally getting around to changing the annoyingly loud fuel pump on my '97 coupe. I am replacing it with a pump from a junkyard '99.
I am having a hell of a time disconnecting the three lines from the fuel pump. I have two different disconnect tools - a two sided, silver one, and a golden one. The silver one is seemingly worthless.
I can fit the gold colored one completely into the fitting on the top. I can't get the tool completely into the fittings on the other two lines.
Even with the tool all the way into the fitting on the top line, I can't get it to disconnect. Pushing, pulling, tugging; nothing has worked yet.
Am I doing something wrong, or is this typically this difficult?
Thanks for your help,
-Mike
Old Dec 31, 2010 | 09:01 PM
Last C5's Avatar
Last C5
The top line and bottom lines are a 3/8" and the center line is 5/16".
Pull the fitting towards the pipe, insert the tool fully, and then move the tool and the line off the pipe. (the tool will stop and the line will come all the way off). The key here is having the proper sized tools.
Old Jan 1, 2011 | 12:54 AM
Bill Dearborn's Avatar
Bill Dearborn
Hopefully, you didn't just buy another noisy fuel pump. They didn't change the pump until sometime during the 99 model run.
Bill
Old Jan 1, 2011 | 01:03 AM
LoneStarFRC's Avatar
LoneStarFRC
If memory serves, I didn't need any tool to remove mine. Push the line forward, squeeze the nylon plastic retainer clip and then pull the lines off.
Old Jan 1, 2011 | 01:08 AM
OpethMike's Avatar
OpethMike
The earlier C5s require a special tool; the later ones have the more sane plastic connectors.
Humorously enough, about 10 minutes after I posted this, I went back to the car and the top and middle lines came off with no problems. Still arguing with the bottom line. Annoying job, but I am hoping the pump I have now isn't a noisy one.
Old Jan 1, 2011 | 01:49 AM
LoneStarFRC
Yeah, I've seen pix of those early lines. They have what appears to be a foam type jacket covering the nylon lines that seems to serve very well as a water sponge and hold water so the metal hardware can rust really well.
I think the foam may have been for heat insulation originally. I know by '99 GM had discontinued it's use as mine does not have it.
I was recently in mine to replace the pump with a Racetronix high volume version along with their wiring harness. Wasn't too bad of a job and the pump is definitely quieter than my stocker, but it had about 150,000 miles on it.
Old Jan 1, 2011 | 05:50 PM
OpethMike's Avatar
OpethMike
Got the new pump in now. Amazing how perfectly you have to angle and maneuver the pump to get it to fit into the tank, past the suspension stuff, etc.
Unfortunately, I do not have light in my garage, and I ran out of day light before I could get the pump screwed in. Didn't realize that the pattern of the holes wasn't even and that the grommet & pump have to line up in a certain way, and then line up a certain way to the pump. Annoying, but I'll get it done tomorrow. Hopefully this pump isn't as loud as my last one.
Old Jan 1, 2011 | 06:26 PM
LoneStarFRC
There should be a mark (line) on the tank itself, to which the "tab" on the gasket and another line on the metal header plate all have to align with each other. It's critical that the gasket be seated/positioned properly so as to not cause leaks.
Did you get your new gasket through Rock Auto or some other source?
Old Jan 1, 2011 | 08:17 PM
Oldvetter's Avatar
Oldvetter
Bill
I was thinking the SAME thing !
You can just use your hands to release the fuel lines, I ended up doing this when I replaced my gas filter.
Old Jan 1, 2011 | 08:36 PM
OpethMike's Avatar
OpethMike
Ah, that makes sense. I was running low on light when I got to that point. I'm sure those marks will stand right out tomorrow.
I didn't know that some of the 99 pumps had noisy pumps as well, but seeing as I paid only $140 for the entire assembly, including fuel level sender, its not that big of a loss if this one turns out to be noisy as well. That said, I'm hoping it isn't!
And you can't use your hands on the early style lines. These aren't the plastic push connectors like you can see in the Lingenfelter pump installation PDF. Definitely need a tool for these. And what a pain in the *** they were!
Old Jan 1, 2011 | 08:56 PM
LoneStarFRC
I would advise cutting back (and removing) that foam insulation on the lines an inch or two to expose the metal ferrules and do a little sanding/scraping off any rust and then giving them a light coat of anti-seize compound or graphite grease. Those are excellent at preventing future rust, plus getting rid of the foam helps stop any water being trapped right on the metal is good too. Avoid using stuff like WD40 or Kroil, etc as they just evaporate too quickly and don't leave any protection. Even a little axle/bearing grease is better than nothing.
I hope you're using a new gasket and screws. If not, be prepared for the distinct possibility of a leak(s). It happened to me when I re-used my original gasket.
Old Jan 1, 2011 | 09:27 PM
OpethMike's Avatar
OpethMike
Good advice, I'll do that. New gasket, but not new screws. We'll see how it goes.
Old Jan 1, 2011 | 09:37 PM
LoneStarFRC
Not sure how you found a new gasket without the new (special break-away) screws that come with it, but so be it. Just be really, really, careful on the tightening, those are brass threads in the tank. Follow a crisscross pattern.
Good luck.
Old Jan 2, 2011 | 03:04 PM
OpethMike's Avatar
OpethMike
New (to me) pump has now been installed. Tightened down screws very carefully as advised. These old style connection fuel lines are as much of a bitch to fit back on as to remove.
There is no leaking from the lines, gasket, tank, etc. And VERY happily, the new pump is very quiet! This project is a success!
Overall, the pump wasn't too bad to change; just annoying. Certainly not as easy as the fuel pump on my DeLorean! (no bttf/cocaine jokes, please!)
Thanks for the tips and pointers, folks.
Old Jan 2, 2011 | 04:44 PM
LoneStarFRC
Great!
Now you are in a position to help someone else someday if they have a problem/question about this. That's the way it works around here.
Just keep a "nose out" () for any fuel smells and check your fuel gauge for correct operation for a few days and you'll be good.
To Changing the fuel pump on a 97 coupe
