More on ACA headlight install
Old Jan 1, 2011 | 09:44 PM
cruisemon's Avatar
cruisemon
Default More on ACA headlight install
Installing the headlight units was a snap. I had to invert the original connector to plug into the ballast/ignitor unit. Also, the wiring harness that allows using high and low beams simultaneously and also allows flashing the high beams for passing uses crimped connectors that don't have a super grip on the two wires. I STRONGLY suggest you take time to solder all the connections on the wiring harness to reduce the possibility of the wire pulliing loose.
Otherwise, these headlights are GREAT! One of the more frustrating discoveries in the install was why my OEM headlights had functioned so poorly. The aim point was almost a foot high at 25'. I feel silly that it never occurred to me check the OEM headlight aim.
I especially like the clean, crisp cutoff for the top of the beam. These headlights will not blind oncoming traffic.
Charlie
Old Jan 2, 2011 | 01:14 AM
Bluefire's Avatar
Bluefire
I was stunned by how awesome my 6000K ACA's were after the install. It seemed like 24/7 daytime.
Congrats.
Old Jan 2, 2011 | 09:57 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I consider it one of the top 10 best C5 mods.
To More on ACA headlight install
