Build Sheet/ Window Sticker
Old Jan 2, 2011 | 04:51 PM
REZ1's Avatar
REZ1
Default Build Sheet/ Window Sticker
My wife tried to order Me a build sheet / window sticker combo from
NCM and couldn't....I called them last week and they said they
can't locate the info for My '01 convertible....anyone else ever run
into this problem.
Last edited by REZ1; Jan 2, 2011 at 04:59 PM. Reason: should be in the Gen. section...please delete
Old Jan 2, 2011 | 05:07 PM
seoulbrooks's Avatar
seoulbrooks
Try to run your VIN# here....
http://www.compnine.com/vid.php
Old Jan 2, 2011 | 05:32 PM
imavettegirl's Avatar
imavettegirl
why is this a tech question?
Old Jan 2, 2011 | 05:43 PM
jrose7004's Avatar
jrose7004
It's not. But it's here!
Old Jan 2, 2011 | 06:09 PM
k24556's Avatar
k24556
When we did our museum Delivery, the person that gave us the tour mentioned that they had a lot of build sheet info sent over from the factory that needs to be gone through and catalogued. It may be that yours is in that stuff. There is a resource center (archive) at the Museum. ask for one of the persons in that area and see if they know.
Old Jan 2, 2011 | 07:28 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There's a copy of it stuffed in the forward frame rail although I don't know which side. Getting to it would be a problem though but its in there. You should try contacting teh Bowling Green Assembly plant with this issue that the NCM doesn't show a record of it.
Old Jan 2, 2011 | 09:01 PM
imavettegirl
why is this posted in tech and general?
Old Jan 2, 2011 | 10:24 PM
2KFRC5's Avatar
2KFRC5
Why don't you PM a Mod?
Old Jan 2, 2011 | 11:00 PM
DaBoz's Avatar
DaBoz
Perhaps he's interested in the technical information on the build sheet... that would be "Tech"....
Old Jan 2, 2011 | 11:09 PM
lucky131969's Avatar
lucky131969
http://forums.corvetteforum.com/c5-t...-magazine.html
Old Jan 3, 2011 | 05:15 PM
SUNNYD 95's Avatar
SUNNYD 95
Why not, does it bother you?
To Build Sheet/ Window Sticker
