Help - car stalling after start - column lock problem?
Old Jan 2, 2011 | 06:41 PM
Jack Daniels's Avatar
Jack Daniels
Default Help - car stalling after start - column lock problem?
Hey fellas. Got an issue. Recently, every once and awhile after I start the car, whenever I try to put it in 1st or reverse to move, and let out the clutch, the car instantly dies. It idles fine - but as soon as I try and let off the clutch in gear it dies immediately. Its almost as if the fuel is being cut straight off.
I can let it sit for a few minutes and the problem seems to go away.
Anyone have any ideas what the problem might be? Someone elsewhere said it sounds like an intermentient column lock problem - but I thought those dealt with an actual physical lock-up of the column?
One other thing to note is on the way to work the other day just before I turned into the parking garage the car went into low power mode and was giving me serious error warnings. Never happened again. Not sure if it is related to the other problem.
Thanks for any help.
Old Jan 2, 2011 | 07:09 PM
dougbfresh's Avatar
dougbfresh
Sounds like the 2mph cutoff for security. If you had any of the later recalls, that's the security now-no column lock, fuel cutoff instead.
Old Jan 2, 2011 | 07:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes please and post them
Old Jan 3, 2011 | 09:46 AM
Jack Daniels
Thanks guys - will check out the codes and report back.
Old Jan 4, 2011 | 12:09 AM
jedblanks's Avatar
jedblanks
Mine does something similar when cold. And it can be hard to restart. No codes or dic messages.
Old Jan 5, 2011 | 10:18 PM
Jack Daniels
OK, I'm back with codes. It's getting worse - about half the time I start it now it will cut out on me as soon as I try and go anywhere, and I'll have to remove the key are restart a few times before the problem goes away.
Codes are as follows:
PCM
p1626h
p1631h
TCS
u1301h
c1287h
c1288h
c1226h
BCM
u1255h
u1016h
b2723h
u1016h
IPC
b0516h
b0521h
u1255h
u1016h
u1064h
u1040h
u1016h
u1176h
u1088h
AO-LDCM
b2284h
RDCM
u1255h
u1016h
u1064h
u1096h
SDM
u1301h
Radio
u1064h
u1016h
u1096h
Other than that, no codes.
Any help appreciated!
Old Jan 5, 2011 | 10:19 PM
Jack Daniels
And sorry for not providing this - 2002 Z06 (stick of course).
As far as I can tell no codes flash when the problem happens.
Thanks again fellas.
Old Jan 6, 2011 | 08:33 AM
dgrant3830's Avatar
dgrant3830
I'm a little concerned by the 1301 code as well...states the serial data line is shorted to the battery but its not a SCM issue rather with the TCS. This would cause a lot of the data line comm problems. What I don't know is where to suggest that you start to find it. Also, the LDCM low battery code...might want to check the status of your battery.
To Help - car stalling after start - column lock problem?
