Head Cam Setup
Old Jan 3, 2011 | 10:24 PM
FBeitel's Avatar
FBeitel
Default Head Cam Setup
So lets say you wanted a cam that had a stock like Idle and pulled hard all the way through to around 6500 RPM. Would a reverse split be the ticket? What heads would be the best for this, ported ls6's or 5.3 stage 2.5's, OR? I do not want a drag car.
Old Jan 3, 2011 | 11:25 PM
sami85L98's Avatar
sami85L98
224/230 with 114+2 on Xe lobe is the ticket from all the way from idle to waay up top, better equipped with LS6 ported, get from TEA LS6 stage 2 don with it.
Iam in heads/cam install process, only rad and small stuff to go in otherwise iam amost complete, dam cant wait another couple, iam nervous, excited and scared...hope this chit fires.
GL man its a lot of work.
Old Jan 4, 2011 | 12:58 AM
jd86L98's Avatar
jd86L98
[IMG][/IMG]
This is what you can do with a 224/230 cam and a good tuner.
To Head Cam Setup
