Clutch Fluid
Old Jan 5, 2011 | 11:08 AM
Rhotrod's Avatar
Rhotrod
Default Clutch Fluid
I read and watched the video on cleaning your clutch fluid and I want to change and clean mine in my 99 FRC with 21,000 miles but I'm unsure what brand fluid to get. When I opened it up it is pretty nasty. Any help will be apprecitated.
Thanks Ron
Old Jan 5, 2011 | 11:16 AM
bumble-z's Avatar
bumble-z
I like to use Prestone Syn Dot 4 Brake fluid. It's clear & once you get your clutch M/C fluid clean, you will be able to see the first signs of cloudiness or minute particulates in the fluid.
Good luck.
Old Jan 5, 2011 | 01:31 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Be sure to BLEED the system after new fluid is installed to get rid of all the air bubbles or it won't work---
Old Jan 5, 2011 | 01:44 PM
Rhotrod's Avatar
Rhotrod
Default Bleed the system
Do you mean by bleeding to do the 30 pumps and repeat until clean.
Old Jan 5, 2011 | 02:06 PM
jedblanks's Avatar
jedblanks
As long as you don't pump the clutch with the reservoir empty, no air should be introduced.
Old Jan 6, 2011 | 01:43 PM
craig04c5's Avatar
craig04c5
Prestone DOT 4 Synthetic is what a lot of people here use. No need to bleed just don't pump it empty like stated above. Just use a turkey baster to empty the fluid reservoir. This is called the Ranger Method.
Old Jan 6, 2011 | 04:25 PM
Rhotrod's Avatar
Rhotrod
Default Clutch Fluid Change
Thanks for all your help it is greatly appreciated. I picked up the Prestone a little while ago.
Old Jan 6, 2011 | 04:34 PM
David426's Avatar
David426
No need to bleed using Ranger's DOT 4 is compatible with DOT 3.. The DOT 4 will withstand higher temps than the DOT 3
To Clutch Fluid
