!@#$!@!!!! Replacing oil pan?
Old Apr 9, 2002 | 12:58 PM
David Lively's Avatar
David Lively
Default !@#$!@!!!! Replacing oil pan?
Ran over a chunk of asphalt on the way home and it punched a series of holes in the oil pan. I managed to get the car home before I lost pressure.
Do you have to remove the front cross member & spring to replace the oil pan? The service manual says yes, but I'd like to hear from someone that's actually done it, or has a better picture of what's in the way.
Old Apr 9, 2002 | 07:59 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: !@#$!@!!!! Replacing oil pan? (David Lively)
:yesnod:
Old Apr 9, 2002 | 08:15 PM
66ImpalaLT1's Avatar
66ImpalaLT1
At some point they changed the pan from 1 piece to 2 piece I think. Do you know which one you have?
I can probably find a photo of each to compare.
Eric
Old Apr 9, 2002 | 08:27 PM
RajunCajun2001's Avatar
RajunCajun2001
Sorry for your misfortune. Hope it all works out.
Old Apr 11, 2002 | 11:45 AM
David Lively
Default Re: !@#$!@!!!! Replacing oil pan? (66ImpalaLT1)
*sigh* Not sure which one I have, but it's at the dealer now getting the dirty deed done. $1500... that could've been a race seat, harness, and a couple of track weekends. D*mn road construction.
To !@#$!@!!!! Replacing oil pan?
