Replacement Torque Tube Torx Bolts
Old Jan 10, 2011 | 01:22 PM
Gearhead82's Avatar
Gearhead82
Default Replacement Torque Tube Torx Bolts
I recently went to adjust my shifter on the Torque Tube, and noticed that the adjustment Torx bolts are starting to get stripped. Does anyone know the thread specs of these bolts, or know where I can find replacements?
These are the bolts in question:
Old Jan 10, 2011 | 01:36 PM
lucky131969's Avatar
lucky131969
Dealership.
Old Jan 10, 2011 | 01:37 PM
Gearhead82's Avatar
Gearhead82
Originally Posted by lucky131969
Dealership.
I've got a feeling they are going to over-charge me for bolts
Old Jan 10, 2011 | 01:47 PM
lucky131969
Of course they will, but it's not like you replace them every two weeks....
So what if they are $5 a piece?..... you have 4 less beers this month.
Old Jan 10, 2011 | 01:48 PM
Gearhead82's Avatar
Gearhead82
Not something I want to deal with , but I'll see if they have them.
If I can get the specs, I'd rather replace them with hex bolts if possible.
Old Jan 10, 2011 | 09:33 PM
C.Davis's Avatar
C.Davis
M8x1.25x27
Old Jan 10, 2011 | 09:38 PM
C.Davis's Avatar
C.Davis
GM part number 12553719 I agree a stealership will charge you 7x what its worth, but thats still not much money....
Old Jan 10, 2011 | 09:44 PM
Gearhead82's Avatar
Gearhead82
Thanks!
Old Jan 10, 2011 | 10:39 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Nobody ever seems to consider how much it costs to manufacture something and sit on it for 10 years until someone comes asking for it.
Old Jan 10, 2011 | 10:42 PM
Gearhead82's Avatar
Gearhead82
Bolts are bolts.
Old Jan 10, 2011 | 10:46 PM
lucky131969
Bolts are bolts.
Just like motherboards are motherboards.....all computer parts are the same.
Old Jan 10, 2011 | 10:54 PM
LoneStarFRC's Avatar
LoneStarFRC
Old Jan 11, 2011 | 09:14 AM
Gearhead82's Avatar
Gearhead82
Not really sure why you would compare computer motherboard to a bolt , but if it makes you feel good...
Instead of making ignorant comparisons, can you explain why a GM M8x1.25x27 torx bolt should be used over a M8x1.25x27 bolt of the same grade from another manufacturer? I honestly would like to know if there is something I'm missing. At some point these forums were useful for learning a thing or two about these cars.
Old Jan 11, 2011 | 10:37 AM
lucky131969
Not sure where the ignorance comes into play here, except with your original statement....."bolts are bolts"........which clearly is not true. Obviously, you qualified further, by stating "of the same grade" above.....which is clearly different than "bolts are bolts". You would be surprised how many people think that it is permissible to use ANY bolt on their car, provided it is of the same length, diameter, and pitch.
Old Jan 11, 2011 | 11:34 AM
LoneStarFRC
Thank you!
Old Jan 11, 2011 | 11:48 AM
corvettebob1's Avatar
corvettebob1
Originally Posted by C.Davis
M8x1.25x27
Ace hardware.
To Replacement Torque Tube Torx Bolts
