P0704 Clutch Switch Circuit ... help?
Old Apr 9, 2002 | 05:31 PM
C5 YA's Avatar
C5 YA
Default P0704 Clutch Switch Circuit ... help?
Anyone ever get this after they installed a Cartek adj master cylinder?
I was just checking to see what codes I had on my DTC and saw this.
The clutch works fine, and I checked the harness for the clutch switch and it seemed okay. Any ideas what to check for next?
Old Apr 9, 2002 | 09:09 PM
Ray'98's Avatar
Ray'98
Default Re: P0704 Clutch Switch Circuit ... help? (C5 YA)
I had a similar problem after a clutch replacement. Turned out to be the switch was bad, easy to check and cheap to replace.
Old Apr 9, 2002 | 09:16 PM
C5Cemo's Avatar
C5Cemo
Default Re: P0704 Clutch Switch Circuit ... help? (Ray'98)
Kosta,
I agree with Ray...it must be a bad sensor. See if your car will start without pushing in the clutch pedal. I assume it does start with the pedal depressed?
I've got the same M/C and have not had this problem.
:seeya
To P0704 Clutch Switch Circuit ... help?
