Power window motor replacement
Old Jan 17, 2011 | 11:34 AM
ant21b's Avatar
ant21b
Default Power window motor replacement
Are the motor and regulator replaced as one unit? What door trim needs to come off to replace the window motor? Is there a procedure that shows what to do to replace the window motor?
Old Jan 17, 2011 | 11:55 AM
owner C4 & C5's Avatar
owner C4 & C5
Go to upandownmainstreet.com to get your answer
Old Jan 17, 2011 | 12:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The motor and regulator are one unit and that's how they come. Pull the inner door cover off and then the moisture barrier. Remove the glass, then remove the motor/regulator assembly. Its an easy job to do as I just replaced my driver's side and it took all of 15 minutes to do and adjust it. Job done.
Old Jan 17, 2011 | 03:32 PM
Jazzkat's Avatar
Jazzkat
I have a drivers side regulator that I purchased from Up and Down Mainstreet and did not use.
I will make you a deal on it.
I am also in SoCal.
To Power window motor replacement
