B2285 Battery #2 Fault
Old Jan 19, 2011 | 06:36 AM
ASarsano's Avatar
ASarsano
Default B2285 Battery #2 Fault
recently my seat memory stooped working i tried resetting the memory but nothing lights above the 2 buttons don't light up nothing works. then i started getting the charging system fault a few times then it went away on its own but my check engine light came on after and it reads B2285 Battery #2 Fault could this be causing the memory from functioning and also what can i do to fix this problem. thanks for any input
Old Jan 19, 2011 | 08:32 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You need to get your main battery, load tested. Its probably getting weak. Now the other possibility could be that the battery connections at the battery or at the starter solenoid are lose, dirty or contaminated.
Old Jan 19, 2011 | 08:47 AM
ASarsano's Avatar
ASarsano
Ok thanks for the tip I'll check it out
To B2285 Battery #2 Fault
