Oil TEMPERATURE Sending unit
Old Jan 21, 2011 | 09:43 PM
Dakota Slim's Avatar
Dakota Slim
Default Oil TEMPERATURE Sending unit
Where is the OIL TEMP sending unit located on an LS6 engine? How easy is it to replace?
Old Jan 22, 2011 | 12:16 AM
LVZO6's Avatar
LVZO6
Right above the oil filter
Old Jan 22, 2011 | 01:50 AM
rustyguns's Avatar
rustyguns
pretty easy up a little on the side above the filter
Old Jan 22, 2011 | 09:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I did not know that. Truly I thought it was in the same location as the Ls1. Learn something new every day here.
Old Jan 22, 2011 | 12:40 PM
lucky131969's Avatar
lucky131969
What do you mean? , it is in the same location.....
Old Jan 22, 2011 | 02:49 PM
dgrant3830's Avatar
dgrant3830
I view it as always on the rear top of the block, not down at the oil filter
Old Jan 22, 2011 | 02:53 PM
lucky131969
You are thinking of the oil pressure sensor, not temp sensor.
To Oil TEMPERATURE Sending unit
