Wheel Alignment Question
Old Jan 24, 2011 | 12:08 PM
hayman's Avatar
hayman
Default Wheel Alignment Question
I recently had my 99 vert wheels aligned. The front tires wore pretty bad on the outer edge.
Since the alignment I've noticed that when pulling into or backing out of a parking spot (turning) my front tire seem to bind up like having a four wheel drive's hubs locked in on dry pavement.
To the best of my knowledge the front has not been lowered and I am running stock sized tires.
Is this normal with a vehicle with wide tires in the front or should I take it back to the alignment place?
Old Jan 24, 2011 | 12:48 PM
RSchleder's Avatar
RSchleder
On my 2000 with 275/18 fronts, I get the exact same feeling in my steering wheel if I turn it all the way to lock or close to it. My son-in-laws CTS-V Caddy does it too.
Old Jan 24, 2011 | 12:55 PM
hayman's Avatar
hayman
I should have added that I did not experience this before the alignment and the car track straight.
Old Jan 24, 2011 | 06:26 PM
GeneT's Avatar
GeneT
maybe you should see a corvette dentist for your alignment
Old Jan 24, 2011 | 08:36 PM
hayman's Avatar
hayman
Mmmkay. Yea maybe I'll do that...
To Wheel Alignment Question
