Hawk LS Series Harmonic Balancer Installation Tool
Here is the Hawk LS Series Harmonic Balancer Installation Tool. It has been on market for over 10 years now and proven itself to be a must when installing a harmonic balancer. Universal installer tool kits do not work well with the GM LS Series motors. No longer do you have to chance stripped or damaged crank threads trying other installation methods.
There are two versions offered, the GM LS1, LS6, LS2 & LS3 or the GM LS7. The GM LS7 version is approximately 3 inches longer due to the deeper crank threads in the GM LS7. So the tool needs to be longer. The GM LS7 version can be used on other LS motors but there may be clearance issues with the added length of the tool during use.
HOW TO ORDER? PLACE YOUR ORDER HERE
HERE FOR GM LS1, LS6, LS2 & LS3
HERE FOR GM LS7
CURRENT DISCOUNT COUPON CODES
If you have any questions, please e-mail or call us as we do not frequent CORVETTE FORUM and may not answer any posts in a timely manner. Thank you.
THIS IS WHY YOU NEED OUR INSTALLER TOOL. THIS VIDEO SHOWS A MECHANIC NOT USING OUR TOOL.
I bought the Hawk install tool a couple of weeks ago and got to use it this past week end to install my balancer. It worked great, I'm so glad that I bought it. I've read threads on the web about guys really having problems with the balancer install but the Hawk tool makes it a very easy install. Thanks for the tool.
Stupid question most likely, but does this ONLY install a factory dampner or could I use this to install an ATI dampner??
Add an outer collar to the tool and you can make it a crank gear installation tool (don't forget a cutout for a keyed crank. I landed up making one out of some roll bar tubing I had laying around, but fabricating stuff like that in the middle of a project eats a lot of time.
Another spam message without answering a simple tech question... what balancers have you used this on? I'd hate to buy it only to find out it doesn't work on some of the popular balancers.
St. Jude Donor '08
Mine has worked on various balancers with ease. One of the coolest tools I have.
1 Post
Just ordered mine too. I've done three of these jobs now on LS1's in C5's. Busted my knuckles each and every time. Not the next one. Bought a used factory crank holding tool off the auction website and now have this. I'm good to go on LS motors for a while!
Cassidy
Cassidy
HERE FOR GM LS7
