ECKLERS Tie Rod Ends?
Old Jan 30, 2011 | 07:24 AM
97Rob's Avatar
97Rob
Default ECKLERS Tie Rod Ends?
I purchased new tie rod ends from Ecklers. They are 3/8" longer than stock. When installed, the threads bottom out to soon not allowing the tie rod end to be screwed in far enough to measure out the same as stock.
Has anyone else used these ends from Ecklers? Looking for some insight.
Rob Edwards
Old Feb 11, 2011 | 09:16 AM
Priorities's Avatar
Priorities
I too purchased Eckler's heavy duty tie rod ends that are longer than need be. My front wheels both point outwards with tie rod ends screwed all the way in. Come to find out, I ordered 4 rear tie rod ends, there is a difference from front to rear. Hope this helps.
Dan
