?Converting a C5 into stripped down bracket car?
Old Jan 30, 2011 | 07:43 PM
JimInPA's Avatar
JimInPA
Default ?Converting a C5 into stripped down bracket car?
I know this will draw a lot of heat (Flame suit is on) but I am contemplating getting rid of my old bracket car and getting into something more interesting. Anyone remember the old HotRod article called Caddy-Hack where they totally stripped down a big block Caddy and trimmed a few seconds off the 1/4 mile times by removing a bunch of weight?
What can be done with the C5? I am talking minimal mods to the LS1 engine but do everything else. Gut the interior, carpets, seats, dash material, add a roll bar, single race seat, get rid of glass and replace with lexan, slicks out back- skinnies up front, possibly a drag race rear suspension instead of IRS, and upgrade the rear end. Also remove smog stuff, A/C, electric water pump and P.S. if possible. Open headers/no exhaust of course. Anyone done anything like this? What do you think a stripped C5 has in it for quarter mile times? There are quite a few cheap C5's out there and a bunch of cash can be regained by selling off the removed parts.
Just getting cabin fever here in snowy Pennsylvania and my mind is racing away!
Jim
Old Jan 30, 2011 | 10:40 PM
chevylad's Avatar
chevylad
I've seen a few pure drag c5s at the track before. They are beautiful cars. I believe the one I saw was a competition eliminator. It was a convertible with no windshield and a closed up passenger side.
Old Jan 31, 2011 | 09:29 AM
rebelheart's Avatar
rebelheart
Use a salvage or wrecked vette,don't butcher a driver that someone else may enjoy and restore.
Old Jan 31, 2011 | 12:44 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Sounds fun! I think every car guy dreams of doing this to every car in some form or fashion. But I second finding a salvage car, there are a number of good sites online that do salvage auctions and are very reputable....
The first one that comes to mind is www.copart.com, they get just about every type of car/bike/truck/boat/motorized vehicle you can imagine, and they're nationwide.
Just a thought...
Old Jan 31, 2011 | 01:29 PM
Rob Petyo's Avatar
Rob Petyo
cut (shave) down every bolt you can find all the way down to the nut
Old Feb 2, 2011 | 05:31 PM
JimInPA's Avatar
JimInPA
I will use a salvage car but if I find the right candidate at the right price. 97/98's are getting pretty cheap also. Either way I was hoping to get more input and ideas. What does a light, stripped down race car have in it 1/4 mile time wise? Mild mods- freshen short block, new heads & cam, open headers, etc. Hopefully lighten it by 300lbs or more.
Jim
Old Feb 2, 2011 | 05:34 PM
feeder82's Avatar
feeder82
Did you see this article, here's your idea to the extreme
http://www.hotrod.com/projectbuild/h...est/index.html
Old Feb 2, 2011 | 07:41 PM
JimInPA's Avatar
JimInPA
Exactly! I didn't know that article existed- it even referenced the Caddy hack I mentioned in the original post.
Of course I don't want to go that extreme but I will do what I can do. Where can I save a few pounds? Gut the interior- no carpets, no glove box door, no radio, no door panels, no console, no passenger seat, plastic drivers race seat. Say goodbye to the glass, all lexan. Say goodbye to the fuel tank and go to a plastic 3 gallon fuel cell. Battery in the back. Smaller radiator. Say goodbye to all the A/C stuff, compressor, hoses, lines, evap stuff, condenser, wiring. Say goodbye to heater ducts, blower, etc. Say goodbye to fat front tires and go to light skinnies. Say goodbye to headlights and related mechinisms. Go to smaller, lightweight alternator. The exhaust system and cats are gone- just lightweight tubular headers. What else am I forgetting? Any guesstimates on how much weight will be lost. Some will be put back with the roll bar or cage depending on how fast I get this thing to go. What does a C5 actually weigh?
I cant wait to get out the saber saw!
Jim
Old Feb 2, 2011 | 09:49 PM
chevylad's Avatar
chevylad
I'd start with a target goal of how fast you want to run and build your car around that. The rules start to get stricter the faster you get. You can get an NHRA rule book from summit. I'm not sure if its free or you get it free if you order enough junk from them. Mines was free.
Old Feb 2, 2011 | 11:06 PM
dragon84's Avatar
dragon84
Jim there is a place in Bristol PA called contemporary corvettes that always has salvaged cars of some form or another. I'd start there. On the plus side they probably have every part you may need.
Tom
Jim
Old Feb 3, 2011 | 12:19 AM
m6 c5's Avatar
m6 c5
Im guessing you are going to drop more than 300 lbs, heck just the door panels are going to drop you about 40lbs then with all the ac and smog stuff gone. You might be able to get it in the 2800 lb range. You would be better starting off with a Zo6 as if Im not mistaken they have an aluminum frame which would drop even more weight.
Old Feb 3, 2011 | 12:24 AM
Jnape's Avatar
Jnape
If a C6 Z06 than yes it is aluminum, C5 is steel frame.
Old Feb 3, 2011 | 12:25 AM
m6 c5's Avatar
m6 c5
I guess I was just figuring that they both had aluminum frames.
Old Feb 3, 2011 | 08:38 AM
JimInPA's Avatar
JimInPA
Tom
Thanks Tom- C.C. is juat a few minutes from me. Problem is that he makes more money selling parts than the whole wreck. I regularly check in and am hoping to find something slavageable at a fair price.
Thanks again.
Jim
Old Feb 3, 2011 | 08:40 AM
JimInPA's Avatar
JimInPA
A cheap, high miles or wrecked Z06 would be awesome but to keep it a lightweight, budget, stripped down racer it seems a coupe is more obtainable. If one is found though it would be a great start!
Old Feb 3, 2011 | 08:44 AM
JimInPA's Avatar
JimInPA
Bracket racing is the goal so speed is not as much of a concern. I am thinking low 11's. If it breaks into the 10's I believe the rules get way more strict.
I am more concerned with reliablity and consistency for bracket racing. Thats why I am going light with mild driveline mods rather than higher horspower in a heavy car.
Thanks for everyones input.
Jim
Old Feb 3, 2011 | 05:45 PM
Redvette_22's Avatar
Redvette_22
Jim
Jim, to get into the low 11's you don't need to strip the car down like you are talking. Many racers in our Corvette Challenge series at Etown can easily run 11.2's with almost, if not all the factory stuff in the car (my own 98 did that back in 99 and still drove 100,000 miles), and that is with a 346 engine. In fact most of "those" cars actually run in the high 10's (and they drive to and from the track each week) but detune them to run a specific "heads up" class....(anyone know who I mean???) so you can achieve your goal and keep the car in "street" trim for eventual resale.
To ?Converting a C5 into stripped down bracket car?
Old Feb 3, 2011 | 05:52 PM
lucky131969's Avatar
lucky131969
.....and make sure you race on an empty stomach. Oh, and go commando.....
Old Feb 3, 2011 | 06:55 PM
Rob Petyo's Avatar
Rob Petyo
I'm signed up to run the 10.5 index at E-town (for points).
346 ci n/a . . . for the heat of summer will probably spray a 50 shot. Now for the rentals with great air I might have to change the jets to 100 - 125 - 150 - 175
Old Feb 3, 2011 | 11:07 PM
chevylad's Avatar
chevylad
If 10's and 11's are your goal, put a roll bar and a big engine. No need to gut it silly. You still have to beef up the drive train, but you can still run an IRS rear. I saw somebody around here who makes hoops for the half shafts in the back.
I was thinking you were wanting run a full tube frame in like an 8.90 index.
