Need some help with a DIY solution of the flasher bypass.
Does anyone have a wiring diagram for the contact under the dash board where you usually plug in the bypass.
Do anyone know where to find the specific contacts that comes with the kit?
I live in Sweden so its a bit of a hassle for me to order one from the US.
Why don't you just use a 2-pin, they are readily available. You sure the 3-pin is a ground and not an opposite contact than the main one (like n/o instead of n/c)?
