Yet Another Spring Bushing Thread, Yes.
Old Feb 2, 2011 | 02:13 PM
LiteraCola's Avatar
LiteraCola
Default Yet Another Spring Bushing Thread, Yes.
I know people are probably getting tired of seeing these threads but I've searched high and low and haven't had much luck. Here's the deal. When I bought my '98 coupe, the PO told me the car was lowered on stock bolts, which is fine. I later noticed that the spring bushings in the rear had been cut, which is also fine (I love the look of a lowered Vette). I noticed something strange about the ride height. the fender gap ont he passenger rear is considerably less than on the driver side. Under closer examination I noticed that the passenger side bushing was indeed cut, but had also been squeeze out from its perch. I've read that you can't buy just the adjusters or bushings from GM without the whole spring. I'd love to upgrade my springs but that will be later on. I haven't been able to find many aftermarket options. I was informed that HardBarUSA sells them, but all I can find is a "spring end kit" (See link).
http://hardbarusa.com/hardbar/produc...products_id=48
EDIT: Checked out CorvetteCentral.com. Part #585054 (spring bushing)....Or Part #585087 (spring mount cushion)
Not sure which is which.
Old Feb 2, 2011 | 07:46 PM
zeevette's Avatar
zeevette
It seems odd that the OP would "cut the bushings" on the rear bolts, because to lower the rear, you unscrew the bolts, to lengthen them, and do the opposite in the front. And yes, you can buy stock, or aftermarket bolts, and nothing else, if you so desire.
Old Feb 2, 2011 | 07:52 PM
LiteraCola's Avatar
LiteraCola
Wow I just re-read my whole post and realized I didn't even get to the point. haha. I'd like to at least have some kind of bushing in there. And was wondering which one of the Part #'s I posted was the correct one. Does that make sense?
Old Feb 2, 2011 | 08:24 PM
lionelhutz's Avatar
lionelhutz
My guess would be the spring bushing. The spring mount pad sounds like the rubber piece that goes between the crossmember and the spring where the spring is actually mounted to the car.
Peter
Old Feb 3, 2011 | 11:07 AM
LiteraCola's Avatar
LiteraCola
Okay, so I checked out Ecklers and found this... Part #: 41509 Leaf Spring Cushion. Thats the part that is actually split and trashed. I found something else (Part #: 41576: Leaf Spring Cushion). Not sure which is which though... I know 41576 is Poly and the other is rubber. But they look nothing alike. Any help would be great. Thanks.
Jesse
Old Feb 4, 2011 | 08:21 AM
LiteraCola's Avatar
LiteraCola
Anyone? I'm surprised more guys haven't gotten in on this. There's gotta be SOMEONE who has experienced this problem...
Old Feb 5, 2011 | 02:46 PM
LiteraCola's Avatar
LiteraCola
t.t.t.
Old Feb 7, 2011 | 07:57 PM
LiteraCola's Avatar
LiteraCola
C'mon guys. Are you kidding me? No one has any input?
Old Feb 12, 2011 | 02:13 PM
LiteraCola's Avatar
LiteraCola
Anyone? Could someone at least give me a visual on how the spring assembly goes together? as far as which bushing goes where?
Old Feb 12, 2011 | 06:12 PM
byronhunter's Avatar
byronhunter
If this is not what you're looking, just say so, ok?
Old Feb 12, 2011 | 09:30 PM
bumble-z's Avatar
bumble-z
That is exactly what he is looking for.
Good job.
Old Feb 13, 2011 | 09:31 PM
LiteraCola's Avatar
LiteraCola
Well, I appreciate that very much. But regarding the two parts I found on Ecklers, whats the difference? They look totally different.
I'm just trying to get this figured out before I order the parts and rip the car apart.
Old Feb 13, 2011 | 10:54 PM
bumble-z's Avatar
bumble-z
Go to MYI's web site.
They are a vendor that has their ad/name to the left side of this page.
Schroll down & click on to their site.
Once there go to the supension C/5 section.
You will see their front & rear adjusters. The rear bolts have the bushings, washers & nuts. Every thing that you will need to get you where you want to be.
Good luck.
Old Feb 14, 2011 | 02:37 PM
LiteraCola's Avatar
LiteraCola
Thank you so much bumble-z. I really really appreciate your help. Corvette project day is back on.
Old Feb 14, 2011 | 02:51 PM
bumble-z's Avatar
bumble-z
Old Feb 15, 2011 | 02:45 PM
LiteraCola's Avatar
LiteraCola
I went ahead and ordered the poly bushings from Ecklers (Part #41576). A set of 4 is the same price as ONE of the normal rubber bushings (Part #41509). Weird. The poly bushings are also shorter than the rubber ones. They're the same as the bushings that come with the lowering kit from MTI. At least I think so...
To Yet Another Spring Bushing Thread, Yes.
