fron hub assembly replacement
Old Feb 2, 2011 | 03:29 PM
DeBaGo's Avatar
DeBaGo
Default fron hub assembly replacement
Well my RF hub had been rattling and creaking for a month or so after a hard pot hole hit. Just last night as I left autozone the front wheel seized completely. I stopped and called a flat bed. I collected 8 or so little bearings on the ground as he loaded her up. how difficult is it to swap it out with hand tools in your own yard? I figured while its off i'll get some cross drilled rotors and new pads on as well ad finally get my car lowered and out of 4x4 mode.
Old Feb 2, 2011 | 04:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've not done the fronts yet but I did do the rears in my '99 some time ago. It only took about 30 minutes each as I remember and the hardest part was separating the ball joint pivot. Standard fork tool worked just fine. Don't forget that you need a strong torx tip driver to take off the 3 torz bolts. I don't know what size at this moment, but Sears has the set of them.
Old Feb 2, 2011 | 04:28 PM
lavery48's Avatar
lavery48
It's pretty easy. With a little bit of skills you should have no trouble.
Old Feb 2, 2011 | 06:19 PM
DeBaGo's Avatar
DeBaGo
Thanks! I'll try to snap pics. Gotta love karma. Car broke down last night, and the part i ordered last week gets here today.
Old Feb 2, 2011 | 06:27 PM
lucky131969's Avatar
lucky131969
Yep, that's what happens when you let things go too long.
Old Feb 2, 2011 | 07:31 PM
byronhunter's Avatar
byronhunter
Torx size = T55
To fron hub assembly replacement
