2002 recalls
Old Apr 11, 2002 | 11:42 AM
nevadacoin's Avatar
nevadacoin
Default 2002 recalls
Does anyone know where I can find 2002 recall notices?? I want to address any open items at my first dealer encounter.... :seeya
Old Apr 11, 2002 | 01:34 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: 2002 recalls (nevadacoin)
Heres all the Technical Service Bulletins for 2002:
#99-01-39-004A Air Conditioning Odor (Install Kit)
#01-03-10-009 Plastic Wheel Nut Covers Missing and/or Loose (Replace Missing Covers and Add Sealant to all Covers)
#01-05-25-004A Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg (Handling) (repair/Reprogram ABS Module)
#01-07-30-038 DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris)
#02-06-04-010 Erratic Fuel Gauge Reading (Reprogram the PCM)
#02-06-04-015 Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt)
#02-08-50-002 Driver Seat Movement During Acceleration and Braking (Replace Adjuster Assembly)
Old Apr 11, 2002 | 02:35 PM
Mark S.'s Avatar
Mark S.
Default Re: 2002 recalls (kewlbrz)
I remember reading that GM recommends putting a sealant on the plastic cover lug nuts, according to the TSB. Am I understanding that they want us to glue the covers on? That is the most idiotic thing I've ever heard of!!! Why don't they make the proper covers and then distribute them to the appropriate Vette owners. I did notice that my "covers" were loose and so I tightened them down. But gluing them in place? Now I know that they're missing a few "screws" in their design department (or should I say "nuts!").
[Modified by Mark S., 12:35 PM 4/11/2002]
Old Apr 11, 2002 | 02:41 PM
ghost.rider's Avatar
ghost.rider
Of course TSB's are not recalls.
Old Apr 11, 2002 | 03:03 PM
kewlbrz's Avatar
kewlbrz
Default Re: 2002 recalls (ghost.rider)
Your right, I didnt mean to imply that.
Recalls can be found at: http://www.nhtsa.dot.gov/
Old Apr 11, 2002 | 05:18 PM
dads01dream's Avatar
dads01dream
Speaking of recalls - Does anyone know of any for a 2001??? I'll probably be taking the car in for service (if I can't fix a few small items on my own) and would like to have any TSB's or Recalls taken care of at the same time.
Thx
Old Apr 11, 2002 | 05:28 PM
kewlbrz's Avatar
kewlbrz
Default Re: 2002 recalls (dads01dream)
Thx
2001 TSB's
#01-08-58-001 Windnoise Around B-Pillar (Add Sealer)
#01-05-25-004 Yellow: Traction Control/Handling Lamp On, Drivers Info Center Displays Service Active Hndlg (Handling) (Repair/Reprogram ABS Module)
#01-05-22-002 Incomplete Brake Pedal Return (Replace Vacuum Brake Booster)
#01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors)
#01-08-64-009 Door Rattle with Moderate to High Audio System Volume (Insulate Door Components)
#01-08-67-003 Squeak From Rear of Convertible Top (Replace Protecotr Assembly)
#01-06-01-023 Higher Than Expected Oil Consumption (Replace Rings)
#02-06-04-001 Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift (Reprogram PCM)
#02-08-111-001 Paint Wear Through at Fifth Bow (Replace Seal)
Old Apr 11, 2002 | 05:31 PM
dads01dream
EEK! A little un-nerving seeing that list. Do you have a link to some website so that I may be able to look these up on my own?? I'd love to see a dealer armed with all this info to avoid any problems in getting warranty repairs.
Thx for the info!
Old Apr 11, 2002 | 05:40 PM
kewlbrz's Avatar
kewlbrz
What I posted are the current ones. Just tell them the TSB and they can look it up. All GM Service Departments get these updates.
Old Apr 11, 2002 | 07:31 PM
dads01dream
Great! Thanks for the help.
To 2002 recalls
