Remove drivers seat
Old Feb 3, 2011 | 03:43 PM
jswizz's Avatar
jswizz
Default Remove drivers seat
Hey guys can anybody tell how to remove the drivers seat.
Need to get new foam installed on the seat.
And how long it will take.
Old Feb 3, 2011 | 03:51 PM
dougbfresh's Avatar
dougbfresh
Romove 2 black covers on the front bottom to expose the 2 bolts there, remove them. slide seat forward, remove rear 2 bolts.
Lift seat up slightly and disconnect the electrical harness(es)-remove seat.
Takes me 5-10 minutes now.
Old Feb 3, 2011 | 04:05 PM
jswizz's Avatar
jswizz
Thanks that sounds easy enough.
Old Feb 3, 2011 | 04:52 PM
99 vett babycar's Avatar
99 vett babycar
go to VettEssentials web site. They have the whole R&R procedure for the seat, foam and covers.
Old Feb 3, 2011 | 05:20 PM
tlove32's Avatar
tlove32
http://www.vetteessentials.com/instr...er_change.html
Old Feb 3, 2011 | 05:33 PM
bumble-z's Avatar
bumble-z
I have my driver's side seat on work bench.
I pulled it out a couple days ago.
Put a heavy blanket over the sill area so you dont scratch it when removing & install.
Good luck.
To Remove drivers seat
