Does blackwing really make more power.
Old Apr 11, 2002 | 01:21 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Does blackwing really make more power.
I have the blackwing on an 02 coupe. I have yet to dyno it but the seat of your pants impression, is not making any more power. Does anyone have a dyno on blackwing on an 2002 coupe. I have heard the stock box on the 02 was better than prior years. I did by the way feel better throttle response when I added a bpp power duct and the blackwing.
Your thoughts please?
Old Apr 11, 2002 | 01:38 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Does blackwing really make more power. (golfman)
Member Tiger Shark, a local guy here, dynoed much better than stock on his '02 coupe. He's one I am familiar with of the top of my head.
RG
Old Apr 11, 2002 | 01:42 PM
carpe dm's Avatar
carpe dm
Better breathing makes for better response and power, although it is hard to detect by you SOTP meter! :yesnod: :)
Old Apr 11, 2002 | 02:26 PM
Red Gump's Avatar
Red Gump
Default Re: Does blackwing really make more power. (carpe dm)
your computer may not have adjusted itself fully yet either.
Old Apr 11, 2002 | 02:29 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Does blackwing really make more power. (Red Gump)
Have had it installed for over 1000 miles and i did the idle relearn when I installed it.
Old Apr 11, 2002 | 03:12 PM
Gunny's Avatar
Gunny
I recommend you read thru this thread, if you already haven't.... there are also some dyno numbers in it.
http://forums.corvetteforum.com/zerothread?id=275319
My '99 definately benefitted from it. She's finally breathing right.
Good luck. :cheers:
Old Apr 11, 2002 | 05:04 PM
JoeCon's Avatar
JoeCon
The blackwing makes more power. After some 1/4 mile runs in stock trim a installed the blackwing and droped my times by .40 and incresed the trap speed by 4 Mph. You will get no improvment with the any aftermarket air chamber im told.
Old Apr 11, 2002 | 06:26 PM
jawski's Avatar
jawski
Default Re: Does blackwing really make more power. (JoeCon)
You will run a little lean when you uncork it with the Blackwing. Get a MAF translator to dial in some richness and then hold on! :yesnod:
To Does blackwing really make more power.
