Leaking Differential Update !!
Old Apr 11, 2002 | 04:14 PM
C5 in 2002's Avatar
C5 in 2002
Default Leaking Differential Update !!
Well I took her in this morning and found out that it was overfilled and the drain plug was loose, I guess the last time they changed the oil they must have overfilled and then did not tighten the plug :mad I will be watching them even closer on oil changes from now on :yesnod: :yesnod: I also ran into a guy with a 99 C5 that was asking about extended warrantees, I told him to check out the corvette forum and Ken Fichtner :yesnod: :yesnod:
Old Apr 11, 2002 | 04:23 PM
Tom/99's Avatar
Tom/99
Default Re: Leaking Differential Update !! (C5 in 2002)
Glad to hear that the leak fix was only minor. That's why I hate for someone else to work on my cars.
Old Apr 12, 2002 | 11:35 AM
gmblack3's Avatar
gmblack3
Default Re: Leaking Differential Update !! (Tom/99)
I had a diff leak on my 01 Z06 at 11,500 miles. David F replaced the seal on the right side.
Here are pics of the leak:
[Modified by gmblack3, 10:38 AM 4/12/2002]
To Leaking Differential Update !!
