tire pressure
Old Feb 6, 2011 | 01:24 PM
ncred02's Avatar
ncred02
Default tire pressure
hankook envos 305-30-19
265-35-18
what are u running? Hankook site recommends 90% of max or 45lbs
Old Feb 6, 2011 | 02:25 PM
jrose7004's Avatar
jrose7004
30 lbs cold as it says in the owners manual.
Old Feb 6, 2011 | 03:01 PM
m6 c5's Avatar
m6 c5
Going to war out the centers at that pressure.
Old Feb 6, 2011 | 06:13 PM
ALLEGRO's Avatar
ALLEGRO
Experiment for the exact pressure based on wear, but I bet you end up right about 30 psi
Old Feb 6, 2011 | 06:25 PM
jaybar's Avatar
jaybar
Bondurant in is book on driving suggests starting with the cars weight divided by 100, then adjust up or down from there. Pretty close to 30 psi.isn't it?
Old Feb 6, 2011 | 07:24 PM
slimsol's Avatar
slimsol
265-35-18
your have low profile tires. your wheels will bent if you dont have enough tire pressure. I have 295/30/20 and my wheels used to get bent after hitting a pothole when i had 30psi. i keep 35 psi cold all around now, no problems
Old Feb 6, 2011 | 07:41 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Sounds like cheap wheels.......
Old Feb 6, 2011 | 07:43 PM
slimsol's Avatar
slimsol
indeed.only paid $500/wheel
Old Jun 22, 2022 | 07:53 PM
5632's Avatar
5632
Don't set at less than 30 psi.
Old Jun 22, 2022 | 08:45 PM
1911tex's Avatar
1911tex
Really old OP thread....however, I go by the driver side door jam label. 30# front and rear..generally add 1# or 2 #.
Old Jun 23, 2022 | 11:49 AM
grinder11's Avatar
grinder11
Sounds like Michigan roads!!! Don't think so? Check out our roads in the Spring, and double up on Dentu Creme, if you have dentures!! I had all 4 wheels bent on my 2014 CTS Cadillac!! That's not cheap wheels, it's physics! Put a 25 or 30 series tire on a 19" or 20" wheel, with a 2-1/2"-3" sidewall, hitting a Michigan pothole=NEW WHEEL TIME
Old Jun 23, 2022 | 10:24 PM
vette4fl's Avatar
vette4fl
30-35 psi
To tire pressure
