Installing a stroker LS2
Old Feb 7, 2011 | 10:22 PM
chevylad's Avatar
chevylad
Default Installing a stroker LS2
I'm putting in a 402, but I found a few things different on the LS2.
- I'm reusing the windage tray and oil pan from the LS1. My H-beam rods are hitting the windage tray. Did you just add a spacer or use an LS2 windage tray.
- The LS1 has lifter valley knock sensors. The LS2 has no provisions for knock sensors in the lifter valley. Did you mount these on the outside of the block?
- I think I know the answer to this one. There is an extra sensor on the back of the block (I think it's a cam sensor). I think the LS2 has the sensor on the front cover and thats's whats in my LS2 conversion kit. I'm gonna recheck the box if it had some directions.
Old Feb 7, 2011 | 10:31 PM
chevylad's Avatar
chevylad
found most the answers if you are doing the same thing:
http://www.ls2.com/forums/showthread.php?t=626014
Old Feb 7, 2011 | 10:42 PM
lucky131969's Avatar
lucky131969
LS2 KS mount on the side, you should have an adapter harness for these. Additionally, I do not believe the knock sensors are the same part number, so using the LS1 KS may not be an option. The cam sensor is in the timing cover, and you should have an adapter harness for that as well. Make sure you wring out all the harnesses with a meter, they are notorious for being pinned up wrong.
To Installing a stroker LS2
