No more abs-traction control issues!!!!!!
Old Feb 9, 2011 | 06:24 PM
dezcapt51's Avatar
dezcapt51
Default No more abs-traction control issues!!!!!!
I have had the dreaded 1243 code on and off for a month now. I read every thread available about the ebcm and bpmv to see what gremlin I had this time. To make a long story short I went out and did some hard starts to about 35-40 then hit the brakes hard. The abs activated perfectly,cleared all codes gone . Thanks to all the great info on the forum
Old Feb 9, 2011 | 08:47 PM
craig04c5's Avatar
craig04c5
I have heard that activating the ABS is a good idea from time to time. Next time it rains I have to do it.
Old Feb 9, 2011 | 09:56 PM
m6 c5's Avatar
m6 c5
I do it every once in a while in the garage since its really easy to activate it due to the slick surface. I also activate it on the street quite often going into some corners hard, traction control/ active handling gets activated pulling out of my street a bunch since there is a little amount of gravel on the road because of a pothole.
I figure its good to activate the functions on the car every so often.
Old Feb 9, 2011 | 10:07 PM
ShootCraps's Avatar
ShootCraps
I did the same thing. No codes is nice.
To No more abs-traction control issues!!!!!!
