Hello everyone...C5 newbie here. Can I cut the stock mufflers/pipes and install the Magna Flows on a set of good ramps, or do I have to trust the kids at the local muffler shop to raise the car properly and install them?
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
cut? most after market mufflers are catbacks, meaning they bolt to the mid pipe before the axles go over the axles to the mufflers and out. are you going to try to scab in some regular car mufflers?? good luck!
No.....I meant....cut off the stock system (one piece). I know that the Magna Flows are 2 piece. Can I remove the stock system by cutting, on ramps or is the car still too low to cut and remove.
Thanks....Tom Woodgeard - Bradenton, Florida
Just cut above the axle and you'll be fine.
After you unbolt the pipes and disconnect the muffler hangers, the exhaust will move a great deal and allow you room to work. I think I only had my car in the air less than a foot and I was just fine.
Yes!!! This is what I needed. It appears I CAN remove the stockers and install the Magna Flows while on ramps.
Thanks for all the replies..........Tom Woodgeard - Bradenton (warm) Florida
Update. I cut the stockers about 5" from the muffler. Pipes fell off (easy).Installed the Magna Flows, driver side easy, passenger side, had to remove heat shield. After that....went well. The tips look fantastic!! The sound.....Idle - slightly louder but deeper. Acceleration.......Louder than stock, but not too much.
Best part.......$643.00 shipped!!!!!! EBay item.
for what its worth i did my axle back install last night and if you dont want to cut the exhaust as i didnt, just unbolt the 2 bolts and 2 nut holding the straps for the sway bar and let it swing down out of the way. jack it up real high and the old exhaust will come out in one piece.
